Old 06-22-2014, 09:14 PM   #1
Nlbloch
Default Touch up paint
Any suggestions on where to buy liquid (not spray) touch up paint for a black coupe?
I prefer to buy locally rather than on - line if possible, but I haven't found a parts store that stocks anything close.
Is there a reference number that matches the standard glossy black?
Nlbloch is offline   Reply With Quote
Old 06-22-2014, 10:34 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Default Re: Touch up paint
No such thing as a standard black.
https://www.fordbarn.com/forum/showthread.php?t=29321
https://www.fordbarn.com/forum/showthread.php?t=134981
https://www.fordbarn.com/forum/showthread.php?t=60320
Old 06-22-2014, 10:51 PM   #3
Logan
Logan's Avatar
How big of area are you touching up? little scratches you can pretty much buy any automotive "gloss" black and use a pin striping brush to brush it over the scratch. Then take some 2000 grit sand paper and wet sand the black down, build it back up with more paint, and repeat wet sanding until the scratch is completely filled. Then flat sand it one last time, and buff/polish it and you will have a hard time seeing the scratch. If you look close, youll see a ring around the outline of the scratch, but itll look way better than having a scratch in the middle of a fender. If it is a big area that youre actually going to have to spray paint on to fix a damaged area, a gloss black will blend pretty easily. just as long as its in the same ballpark of black you shouldnt have a problem blending out a bigger repair area. Just look around while you're out during the day for english color, ppg, sherwin williams, even orielys has a paint store in some of their stores. Napa sometimes sells paint also. It's just keeping your eye open while youre running around to see where paint stores are at.
Cowtown A's
Logan is offline   Reply With Quote
Old 06-22-2014, 11:09 PM   #4
Mike V. Florida
Duplicolor has a "paint line" of a few colors but I cannot vouch for the color match of the black.
You can also try black nail polish.
Old 06-22-2014, 11:15 PM   #5
Mike V. Florida
Originally Posted by 1930 coupe View Post
To fill in small gravel chips, Hobby Lobby has small 1/4 ounce bottles of enamel by the plastic model car kits.
I have found on my car that the Testors brand dries gray compared to the paint already on the fender.
Old 06-22-2014, 11:38 PM   #6
Mikeinnj
Mikeinnj's Avatar
Tom, you did not indicate if the paint is original or a re-paint job.
Original body paint was lacquer and the fenders were enamel. You cannot mix the two.
Test an inconspicuous area of your existing paint with a bit of lacquer thinner to see if the paint disolves. If it does then you want to buy lacquer paint. If it does not then it could be a one stage enamel paint or it might be a modern, base coat/clear coat.
Mikeinnj is offline   Reply With Quote
Old 06-23-2014, 01:54 AM   #7
Growley bear
I bought some at NAPA, a small brush and a ball tip marker. Works very well.
Chet
Growley bear is offline   Reply With Quote
Old 06-23-2014, 09:00 AM   #8
ModelAMike1930
ModelAMike1930's Avatar
Sherman Williams has an auto paint store near me and I brought in a color sample and they can custom mix touchup paint for from $12.00 to $15.00
ModelAMike1930 is offline   Reply With Quote
Old 06-23-2014, 09:06 AM   #9
mshmodela
mshmodela's Avatar
Interesting thread, i'm in the same color boat... I guess buy a few different samples and see...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
