Old 03-24-2014, 09:28 PM   #1
LopezCarguy
LopezCarguy's Avatar
Default black paint color code
So lots of info on paint color codes but not much for Black...and yes yippie there are a number of blacks.... fenders and splach aprons for starters...a cross linked urathane with hardner would be choice..just need code..for 1929 Ford Black
The only thing worth learning is what you learn after you know it all !!
LopezCarguy is offline   Reply With Quote
Old 03-24-2014, 11:03 PM   #2
wrndln
Default Re: black paint color code
I use PPG Concept DCC 9300 to paint all my black items like fenders, splash aprons, etc. I looks good to me.
Rusty Nelson
Old 03-25-2014, 05:54 AM   #3
Kevin in NJ
The DCC 9300 black is the factory pre-mix. It has a yellow bases and hence a yellow under hue.
A deeper black is the DCC 9700 which the dealer has to mix up. It has a blue base and a deeper black (or so I was told). I bought the 9700 and it does look really deep black, I like how it looks.
There are a few different bases of blacks and each has a different look depending on the colors used as the base for the black. The under hue shows up in direct sun light and most people may not be aware of the difference unless they see the paints side by side in the right light.
Oh, I am in no way saying the 9700 is better as I do not really know just wanted to let you know it exists. It was recommended by someone who has done a lot of painting so I went with it. I do know polished up and in the sun it is a real rich deep black with a lot of depth. I am sure you could be just as happy with the 9300 as the DCC paint goes on nice (when I get the gun right) and is not so bad to color sand and polish (got to fix the screw ups).
Kevin in NJ is offline   Reply With Quote
Old 03-25-2014, 06:03 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Actually, 9300 has Strong White and Blue in it. 9700 has the Yellow which is hotter yet has a darker look. It looks the best under artificial lighting. 9000 is the blackest but is the straight toner so it needs something added to protect from UV. We use our own formula/mix with 9000. My suggestion is use what looks most pleasing to your eye. Several years ago when we were hosting the Fordbarn Workshops here, we put two different bodies (one with 9700 & one with 9300) and let the attendees vote on which one they liked best.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-25-2014, 07:27 AM   #5
Kevin in NJ
Humm, I tend to trust Brent as he is in the business. I am a curious sort so I poked around.
But I did a basic google search and turned up this:
the WA8555 is PPG# 9835
9300
Code Description Abs. Cum. Grams Parts
DMD1683 BLACK 486.2 486.2 911.2 100.00
9700
ford codes same color 12, 2N, 4ASAWWA, A, HV, M6018A, M6373A, M6877A, NN, UA, UAWA, UAWAWHA, UAWAXWA, UB, UD, YD / 9517 - BLACK
1C, 4ASAWWA, 632, A, A6, HB, JASAXXA, JASAXXX, M1724A, M1724X, M30J1724, OA / 9300 - BLACK, BLACK AIR FOIL, BRILLIANT BLACK
Chrysler codes same color 13, AC10813, AY110DX8, AY95DX8, DT4014, DX8, FX6, FX8 / 9517 - BLACK
the list goes on and on all just straight DMD1683
woops here is DCC
9700
DMC921 JET BLACK 524.1 524.1 982.2 98.13
DMC934 VIOLET 10.0 534.1 18.8 1.87
9300
DMC921 JET BLACK 533.0 533.0 998.9 99.80
DMC934 VIOLET 1.1 534.1 2 0.20
these are slightly different
as you can see
now for the WA8555
DCC
9835
DMC921 JET BLACK 408.0 408.0 764.6 76.14
DMC902 BLACK 111.1 519.1 208.3 20.75
DMC908 YELLOW 10.0 529.1 18.7 1.87
DMC904 BLUE 5.5 534.6 10.4 1.03
DMC929 LIGHT RED 1.1 535.7 2.1 0.21
DBC
9835
DMD1683 BLACK 435.4 435.4 816 88.92
DMD642 YELLOW 13.7 449.1 25.6 2.79
DMD646 WEAK WHITE 10.7 459.8 20 2.18
DMD1602 GS YELLOW 2.1 461.9 4 0.44
DMD1675 BLUE 2.1 464.0 4 0.44
DBX1689 CLEAR 25.6 489.6 48 5.23
Here is the full link to the place where I got this:
Blackest black
Now where confusion might come in is PPG uses the 9000 numbers for different types of paints (BC/CC vs urethane vs the other stuff) and the formulas might be different. There was talk of a DBC 9700 with a yellow base which I think is BC/CC. As I recall, when I got my 9700 the guy found the BC/CC formula first and almost made the wrong mix.
Anyway, I think it safe to say you are going to get a nice looking black with either DCC 9300/9700.
Old 03-25-2014, 08:59 AM   #6
crock
crock's Avatar
I used nason full-thane 2k urethane ss. Code: Dx8 color black chrysler year 1950. A real deep black color
MY PROBLEM CHILD!
crock is offline   Reply With Quote
Old 03-25-2014, 09:41 AM   #7
kwisor
kwisor's Avatar
I use dupont 99k black i painted a motorcycle with it and loved it i will use it on my tudor when i paint it and and the yellow also the fenders will be black yellow body and paint the wide stripe black
kevinthe yellow is y65p and 72500 clear coat
1930 model a tudor
1923 model t roasdster p/u
kwisor is offline   Reply With Quote
Old 03-25-2014, 12:51 PM   #8
stainless steve
stainless steve's Avatar
Its amazing how many shades and different colors there are ...and to some people that don't paint or see a lot of it don't realize some of the subtle differences ....I had people tell me well just paint it blue or red or white and there are hundreds of shades let alone the difference in hues
stainless steve is offline   Reply With Quote
