Old 05-29-2017, 03:12 PM   #1
michael a
michael a's Avatar
Default oil changes and air cleaners
I just read a thread where the gentleman changes oil between 5 and 7 hundred miles on his A. Not talking about the synthetic oils but your standard multi viscosity oils why is this necesary? Modern oils are so much better now than when these cars were new I do not understand the low mileage oil changes. My A has no air breather, does K&N make one for our cars, or what do you suggest? I do not like starting my car with out a filter, let alone driving it. Thank you in advance for your input...
michael a is offline   Reply With Quote
Old 05-29-2017, 03:40 PM   #2
160B
160B's Avatar
Default Re: oil changes and air cleaners
Do a search and read all the posts. This has been rehashed several times and there are those who do and those who do not run filters. Here is a partial list of past posts.
https://www.fordbarn.com/forum/showthread.php?t=216058
https://www.fordbarn.com/forum/showthread.php?t=211210
https://www.fordbarn.com/forum/showthread.php?t=209923
https://www.fordbarn.com/forum/showthread.php?t=205402
https://www.fordbarn.com/forum/showthread.php?t=142421
https://www.fordbarn.com/forum/showthread.php?t=142838
https://www.fordbarn.com/forum/showthread.php?t=119231
https://www.fordbarn.com/forum/showthread.php?t=119203
https://www.fordbarn.com/forum/showthread.php?t=108962
https://www.fordbarn.com/forum/showthread.php?t=95961
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 05-29-2017, 04:15 PM   #3
mhsprecher
mhsprecher's Avatar
To make your job easier, search on eBay for Model A air filter and you should find one with a K&N filter for your car. I have one for each of my Model A's.
mhsprecher is offline   Reply With Quote
Old 05-29-2017, 04:28 PM   #4
160B
160B's Avatar
here are two more threads.
https://www.fordbarn.com/forum/showthread.php?t=81888
https://www.fordbarn.com/forum/showthread.php?t=77165
Old 05-29-2017, 04:46 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I bought a '59 Studebaker Lark, 6 cylinder, with a broken off air filter! It even had GRIT in the carb throat & a RIDGE this l---l HIGH, on the cylinders!!!
(Comprende' Vous?)
I re-ringed it & it STILL used oil.
Bill Clean
"THE ASSISTANT GURU OF STUFF"
Old 05-29-2017, 06:10 PM   #6
WHN
No oil filter, change oil every 500 miles. I use 20-50w HD oil, with STP. Everyone has their own opinion. Clean oil is cheap insurance. Air filter is also good idea. Suppliers all have them. Just my personal view, use HD oil no matter what was used before. HD oil along with Marvel Mystery Oil in your gas will make your valves very happy. Don't forget transmission, rear end, and important "u-joint". Also clean vent on shift tower for transmission.
Old 05-29-2017, 09:48 PM   #7
Utopia Texas
Utopia Texas's Avatar
Even the cheapest crummy lawn mower engines from China have air filters. With what it costs to have a Model A engine rebuilt I have never understood the attitude that "since they did not come with air filters they are not necessary."
What others do with their money is no one else's business but a little common sense goes a long way......
Utopia Texas is offline   Reply With Quote
Old 05-29-2017, 10:57 PM   #8
160B
160B's Avatar
FWIW
Here is an economic analysis of changing oil for 4500 miles every 500 miles without an a K&N air cleaner and changing oil every 1500 miles with a K&N air filter.
W/O K&N air filter oil change every 500 miles
Air filter cost $0.0
9 oil changes @ 4 qts $2.55? qt = $91.80
W/ K&N Air Filter
Air Filter cost $48.99
Air maze filer housing $24.95
3 oil changes @ 4 qts $2.55? qt = $30.60
Total cost $104.54
Old 05-29-2017, 11:18 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by 160B View Post
FWIW
W/ K&N Air Filter
Total cost $104.54
Nice try. But then the next 4500 miles you spend the same $91.80 on oil changes every 500 miles for a total of $183.60 for 9000 miles vs 3 more oil changes with filter (because you don't have to replace a K&N filter and Air Maze housing) for $30.60 for a total of $135.14 for 9000 miles.
Old 05-29-2017, 11:28 PM   #10
Y-Blockhead
Michael, as you can see in my picture, I'm on the side that believes in filters, air, oil and fuel...
Old 05-29-2017, 11:28 PM   #11
160B
160B's Avatar
Thank you!! I did not run all the numbers out, as at 1500 miles if you do not see the difference you will not recognize the benefit of running a good air filter to protect the engine life, and at a cost savings!!
I also feel that an air filter benefits engine life!!
Old 05-30-2017, 10:12 AM   #12
captndan
captndan's Avatar
At 2-3K for a rebuild there is no such thing as saving a buck or two. Henry is no excuse here.
captndan is offline   Reply With Quote
Old 05-30-2017, 10:57 AM   #13
Chris Haynes
Chris Haynes's Avatar
Your Model A Carburetor is jetted for no air cleaner restriction. Adding a air cleaner does restrict air flow. Your carburetor must be adjusted to compensate. I am in the process of changing to a Holly down draft with air cleaner.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 05-30-2017, 01:27 PM   #14
Fullraceflathead
Fullraceflathead's Avatar
This IS the Reason you use a K & N Filter. The K & N Filter offers NO Restriction.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 05-31-2017, 11:39 AM   #15
Jim Brierley
Use an oil filter, change oil at 2-2500 mile intervals, works for me.
Old 05-31-2017, 12:11 PM   #16
SeaSlugs
SeaSlugs's Avatar
FYI your forgetting the $15 K&N filter cleaning and oiling kit that once the purple fades or gets dirty it needs cleaned so there is a cost to the K&N. Thier website says 20-50K miles but ive found on my modern truck it needs it more (darn cottonwood seeds and danelion seeds clog them up bad and they stay stuck due to the oil - dry paper you can blow off with an air nozzle.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-31-2017, 10:57 PM   #17
midgetracer
midgetracer's Avatar
One concern about the updraft air filters is potential of fire. My friend had a air maize with the paper filter. On a trip to Canada, his car backfired during startup and the paper filter had absorbed the excess gas from choking. The resulting fire almost reduced his car to ashes. By the time he realized what was happening the fire had caused significant damage to the engine compartment , hood and firewall. luckily the car was saved before the fuel tank caught fire. I would only use a filter mounted above the carb.
midgetracer is offline   Reply With Quote
Old 06-02-2017, 07:53 AM   #18
Hoovercw
I recently installed an air filter on mine and was concerned about it's proximity to the exhaust pipe. Anyone have a picture of a setup that routs the air cleaner a different way?
Hoovercw is offline   Reply With Quote
Old 06-02-2017, 08:03 AM   #19
V4F
V4F's Avatar
I change my oil spring/fall . daily driver in town with filter .
V4f
V4F is offline   Reply With Quote
