Old 01-28-2013, 05:30 PM   #1
ba49
Default K&N replacement for Air Maze
I'm not sure if this has been posted before but I didn't see it in the archives. I found the replacement no. for the K&N replacement for the high volume Air Maze filter. You will have to use a piece of all thread and a wingnut to extend a standard length filter. The K&N no. is E-9257. This is the cleanable filter that will pass more air than the paper filters. It fit right into the holder and works great on both of my As. It was $37.50 at Auto Zone and they had it in one day. It should be cheaper in the long run as you clean and reoil instead of having to replace it.
Bill
ba49 is offline   Reply With Quote
Old 01-28-2013, 06:00 PM   #2
160B
160B's Avatar
Default Re: K&N replacement for Air Maze
I use the K&N E-3050 Custom Air Filter available on line at ajusa.com for $25.59 and the cleaning kit for $12.95. Get together with some fellow club members and order enough to get free shipping for orders over $75.
This filter is 3.5 in OD and 3.5 in length and fits in my original air maze housing with a longer bolt. This filter is closed on one end and all you need is a longer bolt and drill a hole in the closed end of the filter. Have one on my 31 slant window for 10+ years and 30,000 miles.
Filter
http://www.ajusa.com/K-and-N-E-3050-...er-a1c81a.html
Cleaning kit
http://www.ajusa.com/K-and-N-Filter-...Kit-c2808.html
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 01-28-2013, 06:10 PM   #3
ba49
I wanted the longer one to pass more air but either will work. It has the 3.5" outside diameter but is 5.5" long. It fits tightly inside the housin and the endcap. I'm sure it can be found cheaper online somewhere.
Old 01-28-2013, 06:14 PM   #4
160B
160B's Avatar
The K&N E-9257 Custom Air Filter available on line at ajusa.com for $28.89.
http://www.ajusa.com/K-and-N-E-9257-...er-a1cadd.html
Old 01-28-2013, 08:15 PM   #5
glenn in camino
glenn in camino's Avatar
I bought one that has a curved pipe routing the K&N filter under the carburetor. Works great.
glenn in camino is offline   Reply With Quote
Old 01-29-2013, 08:15 AM   #6
Clydes 31 P/U
I'm with Glenn, I got the U shaped air maze tube then added an E-2190 K&N filter at a length of 5 3/4 X 4" dia. If I do get any gas drips they run down and out lower and farther forward than if they came out of the carb.
Clydes 31 P/U is offline   Reply With Quote
Old 01-29-2013, 10:19 AM   #7
AL in NY
AL in NY's Avatar
Clyde, I had the same filter setup that you are running, but opt'ed for the Hi-Boy filter also made by "Fit-It-Eddie, LLC". It has the same large K&N filter element, but it sits above the carburetor so there is no chance if it becoming saturated with fuel, which can cause hard starting or a fire.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-29-2013, 03:37 PM   #8
hugeal
Hi.
This is sort of a shot in the dark, but could it
but your engine tick be you have the wrong oil dip stickstick and the tick is the noise that you hear night be from the crank hittingthe stick.?hitting the stick?
Al
hugeal is offline   Reply With Quote
Old 01-29-2013, 06:28 PM   #9
1931 flamingo
1931 flamingo's Avatar
P in CT
Old 01-29-2013, 10:03 PM   #10
160B
160B's Avatar
Originally Posted by hugeal View Post
Hi.
Al
I think your comment belongs on the thread "Engine "click" noise-Need some help"
https://www.fordbarn.com/forum/showthread.php?t=88415
Old 02-05-2013, 10:22 AM   #11
Growley bear
Bert's has K&N air filters.
Growley bear is offline   Reply With Quote
Old 02-05-2013, 10:45 AM   #12
29ModelA
29ModelA's Avatar
As an aside, is there any way to keep an Air Maze from rattling loose? Mine is constantly falling off, and I am scared I am going to crack the carburetor if I tighten it anymore.
1929 Model A Barn find. California car, just a few more parts to find.
Interior, steering box (rebuild), and I am sure much more!
29ModelA is offline   Reply With Quote
Old 02-05-2013, 11:32 AM   #13
1931 flamingo
Good luck, lost the first one I'd put on.
Not using one now.
Paul in CT
Old 02-05-2013, 01:38 PM   #14
160B
160B's Avatar
Here is a photo of the original Air-Maze on my car with a K&N E-3050 air filter. I have had this assembly on for approximately 12 years and 30,000 miles. The set screw has never become loose, in part due to the locking nut that is tightened down just like the set screw for holding the distributer in the head. If the reproduction Air-Maze does not have a locking nut adding one could keep you from losing the Air-Maze and the K&N filter.
Old 02-05-2013, 01:47 PM   #15
29ModelA
29ModelA's Avatar
Looks like I need to add a locking nut, Thanks! The repro doesn't have it.
