#1 |
Anybody know how to keep 1940 thermostates from ending up up inside the hose---upside down and backwords------------???????????or just go back to the stock ones--------------they worked when the cars were new----?????????--------
#2 |
Drill two small holes toward the top of the neck of each head and the rim of the T stat. Use thin gauge stainless safety wire, tied them down and reinstall hose.
The factory hoses had a flare in the part where they connect to the head to keep the T stat in place. I've had very good luck using Stant Super Stats @ 180 degrees. I believe they fit Subaru Justys. |
#3 |
Ten years ago I bought reproduction hoses with the molded flare from one of the usual vendors. Never had a traveling stat problem. Are these molded flare hoses no longer available?
#4 |
I just out a second hose clamp above the thermo to keep it home …
#5 |
Just put a hose clamp an inch above the stat, and just squish the
hose a little bit, just enough to keep the stat from creeping up. ![]() . .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV.
#6 |
#7 | |
Rick @ Noble Speed makes a nifty solution as well. Those Super Stats welded into a piece of stainless pipe. https://www.noblespeedequipment.com/...ne-thermostats |
#8 |
I do like Mart does. A hose clamp at the head, and another at the short tube.
#9 |
I cut a piece of hose that fits snugly inside the existing hose and use a polyurethane marine adhesive, usually Sikaflex to keep them in place. These inserted pieces are about 1 1/2" long. And x2 on the subaru justy thermostats.
#10 |
I do what Mart does, 1" of stainless steel tube inside. Keeps thermostat in position.
#11 |
I have never had to add anything to a thermostat or use a second hose clamp on any 37-48 style V8 engine. I have used the hoses with the molded flare where they go over the head. I just set the thermostat on the head outlet, shove the hose down over the thermostat and head outlet, and tighten the hose clamp.
I did a quick look around for these types of hoses for 1939 Deluxe / 1940 / 1941 V8 and found they are out of stock. Sign of the times we live in. |
#12 |
#13 |
The best way to fix this is to go back to the stock thermostats--they are much larger and cant go up the hose----ford had it figured out----ebay stuff now 155---temp------------- and they open up not down----
#14 |
They make the original hoses-----they do have a flare to them---some people are out of stock i did get a set of new ones-------i was lucky---
