Old 09-13-2025, 05:25 PM   #1
GUERRINIRACING
Default Guerrini
Anybody know how to keep 1940 thermostates from ending up up inside the hose---upside down and backwords------------???????????or just go back to the stock ones--------------they worked when the cars were new----?????????--------
GUERRINIRACING is offline   Reply With Quote
Old 09-13-2025, 06:28 PM   #2
Tim Ayers
Default Re: Guerrini
Drill two small holes toward the top of the neck of each head and the rim of the T stat. Use thin gauge stainless safety wire, tied them down and reinstall hose.
The factory hoses had a flare in the part where they connect to the head to keep the T stat in place.
I've had very good luck using Stant Super Stats @ 180 degrees. I believe they fit Subaru Justys.
Old 09-13-2025, 07:26 PM   #3
JayChicago
JayChicago's Avatar
Ten years ago I bought reproduction hoses with the molded flare from one of the usual vendors. Never had a traveling stat problem. Are these molded flare hoses no longer available?
JayChicago is online now   Reply With Quote
Old 09-13-2025, 07:41 PM   #4
TomT/Williamsburg
TomT/Williamsburg's Avatar
I just out a second hose clamp above the thermo to keep it home …
TomT/Williamsburg is offline   Reply With Quote
Old 09-13-2025, 10:10 PM   #5
Lanny
Lanny's Avatar
Just put a hose clamp an inch above the stat, and just squish the
hose a little bit, just enough to keep the stat from creeping up.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 09-14-2025, 03:42 AM   #6
Mart
Mart's Avatar
Or push a piece of stainless tubing up the hose a little so the stat can't drift up. A strip bent into a circle will do if no tub available.
Old 09-14-2025, 06:14 AM   #7
Tim Ayers
I think the ones from Bob Drake have the flare. I've been seeing some that do not have that molded in.
Rick @ Noble Speed makes a nifty solution as well. Those Super Stats welded into a piece of stainless pipe.
https://www.noblespeedequipment.com/...ne-thermostats
Old 09-14-2025, 07:34 AM   #8
alchemy
alchemy's Avatar
I do like Mart does. A hose clamp at the head, and another at the short tube.
alchemy is offline   Reply With Quote
Old 09-14-2025, 08:19 AM   #9
GB SISSON
GB SISSON's Avatar
I cut a piece of hose that fits snugly inside the existing hose and use a polyurethane marine adhesive, usually Sikaflex to keep them in place. These inserted pieces are about 1 1/2" long. And x2 on the subaru justy thermostats.
Old 09-14-2025, 08:36 AM   #10
37 truck
I do what Mart does, 1" of stainless steel tube inside. Keeps thermostat in position.
37 truck is offline   Reply With Quote
Old 09-14-2025, 07:58 PM   #11
38 coupe
38 coupe's Avatar
I have never had to add anything to a thermostat or use a second hose clamp on any 37-48 style V8 engine. I have used the hoses with the molded flare where they go over the head. I just set the thermostat on the head outlet, shove the hose down over the thermostat and head outlet, and tighten the hose clamp.
I did a quick look around for these types of hoses for 1939 Deluxe / 1940 / 1941 V8 and found they are out of stock. Sign of the times we live in.
Old 09-15-2025, 08:17 AM   #12
Bored&Stroked
Bored&Stroked's Avatar
I do this and put a second hose clamp to keep the short piece of stainless in place - works perfectly.
Old 09-15-2025, 10:42 AM   #13
GUERRINIRACING
The best way to fix this is to go back to the stock thermostats--they are much larger and cant go up the hose----ford had it figured out----ebay stuff now 155---temp------------- and they open up not down----
Old 09-15-2025, 10:46 AM   #14
GUERRINIRACING
They make the original hoses-----they do have a flare to them---some people are out of stock i did get a set of new ones-------i was lucky---
