Old 11-07-2024, 11:57 AM   #1
LITTLECHRIS
Default Looking for these original OE cage nuts
Hey guys,
I’m working on putting my 1934 truck cab back together, and I am missing some cage nuts that are riveted into D-shaped holes. Does anyone one know if there is a source for them? I’ve checked a few of the parts suppliers but have only come up with the standard cage nuts or D-clinch nuts. The 1/4-20’s attach the roof to the pillars and the 10-32 hold in the windshield. Please look at the pics to see what I’m after.
THANKS!
LITTLECHRIS is offline   Reply With Quote
Old 11-07-2024, 12:03 PM   #2
LITTLECHRIS
Default Re: Looking for these original OE cage nuts
Here it is
Old 11-07-2024, 12:08 PM   #3
kurt v
look up Restorationspecialties.com they have a ton of parts
kurt v is offline   Reply With Quote
Old 11-07-2024, 12:26 PM   #4
rockfla
rockfla's Avatar
ALSO, IF you like you can also look at the "weld" style cage nuts there too
https://www.mcmaster.com/products/ca...-snap-in-nuts/
Old 11-07-2024, 12:56 PM   #5
Bob C
Snyder's https://www.snydersantiqueauto.com/s....htm?cat=41715
Old 11-07-2024, 01:09 PM   #6
LITTLECHRIS
Originally Posted by Bob C View Post
So those rivet in then? Cool.
Old 11-07-2024, 06:04 PM   #7
mcgarrett
They don't rivet into place; you peen them into the pre-punched hole.
mcgarrett is offline   Reply With Quote
Old 11-08-2024, 07:25 AM   #8
Terry,OH
Terry,OH's Avatar
The cage nuts need to have the cage welded or spot welded in place. The D-nuts are peened into the D shaped hole and both come in various sizes. You may not find the exactly same cage shape
Old 11-08-2024, 08:08 AM   #9
nelsb01
nelsb01's Avatar
Try ThirdGen for the D nuts that you are looking for. (not called cage nuts as they are different)
I got the ones I needed from Roy Nacewicz (now sold through Third Gen) years ago.
They may have them...... may not.
nelsb01 is online now   Reply With Quote
Old 11-08-2024, 11:53 AM   #10
LITTLECHRIS
I ordered the D-nuts from Snyders this morning. Before I even made this post I checked all of the suppliers mentioned. Again, my intent was to come up with what was originally in place, not a substitute. The D-nuts should work fine once peened in place.. if they match the existing holes!!! lol it’s always something.
Thanks!
Old 11-08-2024, 01:40 PM   #11
flathead4rd
flathead4rd's Avatar
Try Granger.com
flathead4rd is offline   Reply With Quote
