Old 05-14-2020, 01:24 PM   #1
qmdv
qmdv's Avatar
Default 39 transmision build
I am putting together a 39 box with standard gears that are up through 1948. The 1/4 inch pin that keeps the gear shift lever ball oriented is really sloppy. What is the best way to fix that. In Vern Tardel trans book it says weld it up and remachine. Is that the only option out there. How about an oversize pin.
qmdv is offline   Reply With Quote
