Old 03-26-2017, 08:30 PM   #1
v8fordman
v8fordman's Avatar
Default Locking Spare Identity
Can anyone help me identity what this is or what it fits?
v8fordman is offline   Reply With Quote
Old 03-26-2017, 08:34 PM   #2
160B
160B's Avatar
Default Re: Locking Spare Identity
Spare tire lock for Model A Ford. Accessory item, two different manufacturers.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 03-26-2017, 09:08 PM   #3
v8fordman
v8fordman's Avatar
Is there a way to identify who made it? Does anyone know who could make a key for it? I would be interested in putting it on my car since I found it at my dad's house after he passed away.
Old 03-26-2017, 09:32 PM   #4
Brian SATX
Brian SATX's Avatar
Look on the band itself and the lock. It should have a name. Fox was one and I cannot remember the other.
Edit- Oaks is the other company
Any good locksmith can make a key for you.
You will need the special lug nut for it. Hopefully that is with it.
A-13805AR is for 21 inch wheels
A-13508-C is for 19
Brian SATX
Brian SATX is offline   Reply With Quote
Old 03-27-2017, 12:23 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
It appears to be a 1930 unit.
Bratton's part number 25580
This is from the Restoration Guidelines (a book every owner should have),
Old 03-29-2017, 04:50 PM   #6
v8fordman
v8fordman's Avatar
Found out this one is a Fox. Still would like to know where I can get a key made if anyone has a suggestion.
Old 03-29-2017, 08:01 PM   #7
SeaSlugs
SeaSlugs's Avatar
Go to a lock smith - bring it with you and see what they say. Shouldnt be that hard to get a key made if they truley are a locksmith and not just a key cutter.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 03-29-2017, 08:47 PM   #8
Doug Clayton
Most lock cylinders are frozen due to the pot metal swelling. Before, going to far, try turning (in both directions) the lock cylinder with a small screwdriver. Don't twist very hard as it will break. If you get slight movement a locksmith can make a key. If no movement then a pin on the side of the lock must be removed and the lock cylinder and retaining sleeve taken out. Then it MAYBE repaired. Lock cylinders are out there but difficult to find.
What is the part number on the strap? These are marked with the part number A-18305 with or without a suffix. Suffixes include A, A1, A2, B, C, D and E. This important if you want one to fit your car.
Doug Clayton is offline   Reply With Quote
Old 03-29-2017, 08:48 PM   #9
barnstuf
The correct Ford part numbers are 28-29 A18305-AR and 30-31 A-18305-C and it has not been stated, although obvious to most, that it is for the rear mounted spare only.
barnstuf is offline   Reply With Quote
Old 03-31-2017, 12:20 AM   #10
Mike V. Florida
Originally Posted by Doug Clayton View Post
Most lock cylinders are frozen due to the pot metal swelling. Before, going to far, try turning (in both directions) the lock cylinder with a small screwdriver. Don't twist very hard as it will break..
DO NOT USE WD40 to loosen it.
Old 03-31-2017, 06:34 PM   #11
Chris Haynes
Chris Haynes's Avatar
Why not? The WD40 can always be washed out. With that being said I would soak it in Kroil for a couple days.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 03-31-2017, 06:55 PM   #12
SeaSlugs
SeaSlugs's Avatar
https://www.fordbarn.com/forum/showthread.php?p=1427486
read and specifically the chart in freeing things up Chris.
WD-40 is really bad for locks as it doesnt penetrate like a legit penetrating oil should, leaves a sticky residue after a while, and gums up locks something fierce.
I would do the atf and acetone mix in a small cup and let it soak for a few days. (acetone eats alot of plastics and especially foam so put it in something acetone proof)
Old 03-31-2017, 07:16 PM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Minerva came with a band lock, but it left an UGLY crease in the Firestone Deluxe 19" tires.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 03-31-2017, 08:31 PM   #14
v8fordman
v8fordman's Avatar
Cleaned the back side today and it is a A-18305-C. Has anyone ever used Gibbs Brand to loosen parts like this? I may try the ATF/Acetone or the Gibbs.
There is no locksmith around here that I would trust, so if anyone has a suggestion, I would send it to them.
Old 03-31-2017, 08:47 PM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
I've used Gibbs with pretty good luck. I've also used Kroil, as it's sold 5 miles down the road, but I can't find Gibbs for the past several years. I have a Maytag soaking with ATF/Acetone, but haven't tried it for a long time.
Old 04-01-2017, 06:55 AM   #16
ken will
Your local Police station might be able to suggest a locksmith.
ken will is offline   Reply With Quote
Old 04-01-2017, 10:39 PM   #17
Mike V. Florida
Originally Posted by Chris Haynes View Post
Why not?
Do a search on Pot metal and WD40, there are too many stories about the metal failing to take a chance when there are so many other choices.
