Old 02-24-2017, 10:14 AM   #1
jwilliams81
jwilliams81's Avatar
Default Non-removal leaf spring lubricant?
I wanted to ask what you guys would do to lube the springs without removing them from the car. I just got her running and I would like to be able to drive her for the summer before really tearing into the springs and removing them.
So this would be a temporary solution.
I was thinking I could unload each side at a time and either spray Slip-plate, or some type of PTFE Dry Teflon Lubricant on and in between the leaves.
Which would be better?
I have been spraying them with PB blaster to get them moving and that worked really well.
Let me know your thoughts.
Thanks
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 02-24-2017, 10:20 AM   #2
eagle
eagle's Avatar
Default Re: Non-removal leaf spring lubricant?
They make a spring greaser that wedges/clamps between the leaves, then uses a grease gun to force grease in. Haven't used one myself.
Here is a greaser on ebay right now, different type though...http://www.ebay.com/itm/Tomahawk-Mfg...YAAOSwr~lYq5HM
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 02-24-2017, 10:56 AM   #3
jwilliams81
Thanks Eagle,
I have seen those, but I didn't want to spend that much on one yet.
Cincinnati, Ohio
Old 02-24-2017, 11:06 AM   #4
Mitch//pa
Jack up the car and support by the frame so the suspension unloads.
Take a tapered chisel or such and spread open each leaf to lubricate...
Wear gooogles
Removing the spring clamps may help
Old 02-24-2017, 12:06 PM   #5
katy
katy's Avatar
This works to spread the leaves:
Old 02-24-2017, 12:35 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
My 29 Tudor was bone dry and had the typical red rust showing on the springs edges. It rode like a lumber wagon. Just squirting oil all over the springs made a world of difference.
I see restored and nice original cars at the meets with dry springs and rust showing, and can only shake my head and wonder.
Old 02-24-2017, 12:49 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
There is a lube point in the hand crank bearing after some time in 29 that helps lube the front spring--- while I had the oil can I squirted the springs --- front and back , made a mess, then after 20 miles I had to tighten the shock adjustment some to stop the bounce, made the ride better too
Old 02-24-2017, 01:31 PM   #8
Chris H
Chris H's Avatar
I unloaded my springs, as Mitch suggested, but sprayed mine with a graphite lube that I got from my local NAPA store. Admittedly, not as good as grease, but sure stopped the squeaking and red rust. At least for now. I am about due for a reapplication too. I think they have both a liquid and a dry product in a spray can. I think I used both, thinking the liquid would penetrate better and carry some of the dry in with it.
Chris H.
1930 Tudor
1964 MGB
1979 MGB
Ham call: N9WHH
Chris H is offline   Reply With Quote
Old 02-24-2017, 01:34 PM   #9
Mitch//pa
I think that would lube the saddle contact point more then the actual leave separation....
Most dont know about that hole
Old 02-24-2017, 01:44 PM   #10
jwilliams81
Thanks guys. I guess I thought that if I unloaded the springs, without taking them off the car, and not using a spring spreader I could work in some type of lube.
What would be the best type of lube to actually use in that instance?
Cincinnati, Ohio
Old 02-24-2017, 02:08 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
Have you tried PB Blaster with Graphite? Spread them apart and spray. After the carrier fluid drys it leaves a graphite coating on your springs. Be carful of overspray, it's hard to remove after it drys (especially on painted surfaces).
After I lubed mine with the graphite I greased them and installed spring covers to keep water and dirt off of the leaves. The covers also have a pad that you apply grease/oil to.
Below is a picture of a tool I made out of some round stock for lubing leaf springs.
Old 02-24-2017, 02:14 PM   #12
Kurt in NJ
Kurt in NJ's Avatar
I just oiled that first over several drives and watched the oil spread down the leaves--- I did seal around the hole to the frame when putting on the crank bearing so all the oil went down to the spring
This is also the same time I realize d that a good squirt of oil in the dist oiler oiled the top bushing
Old 02-24-2017, 09:32 PM   #13
Tom Wesenberg
Oil will seep in and spread to do a great job. Use an oil can to squirt, or use a 1/2" or 1" wide paint brush dipped in drain oil. Drain oil will work as well as new oil. Do it in the grass or dirt so you don't have drops on your driveway.
Old 02-24-2017, 11:51 PM   #14
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
I like that.
Old 02-25-2017, 03:43 AM   #15
Synchro909
Synchro909's Avatar
I've often seen people suggest here that a seized nut or bolt can be freed with a mix of ATF and acetone. Would that not work on the springs?
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 02-25-2017, 05:58 AM   #16
Dollar Bill
Dollar Bill's Avatar
It will work to get the springs moving and help with running rust but long term, I think ATF is too thin to provide much lubrication.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 02-25-2017, 08:45 AM   #17
Kurt in NJ
Kurt in NJ's Avatar
Atf will work, in 1936 Ford put fittings on the centerbolt for spring lube, the spec for spring lube was somethiimg like 77% ice machine oil, the balance talc with a touch of ground asbestos, ice machine oil is about the weight of ATF, talc is a dry lube/ polishing media used in some slip plate products
If you don't have properly working shocke leave your springs dry---the dry springs dampen movement in the place of shocks
Old 02-25-2017, 09:34 AM   #18
old31
Very clever and well done. Does the entire tube fill up with grease before it needs to squirts out?
Old 02-25-2017, 11:01 AM   #19
Y-Blockhead
Thanks old31. The 'Tube" is solid. The hole for the grease is only from the zerk fitting to the outlet.
I would like to take "credit" for the design but I copied it from one I seen on epay. I see them occasionally, usually from England.
Old 02-25-2017, 11:05 AM   #20
Y-Blockhead
Here is one on epay now. I'm to cheap too buy one so I made my own...
http://www.ebay.com/itm/RARE-LEAF-SP...8AAOSwB4NWyhG7
