Old 02-24-2017, 10:14 AM   #1
jwilliams81
jwilliams81's Avatar
Default Non-removal leaf spring lubricant?
I wanted to ask what you guys would do to lube the springs without removing them from the car. I just got her running and I would like to be able to drive her for the summer before really tearing into the springs and removing them.
So this would be a temporary solution.
I was thinking I could unload each side at a time and either spray Slip-plate, or some type of PTFE Dry Teflon Lubricant on and in between the leaves.
Which would be better?
I have been spraying them with PB blaster to get them moving and that worked really well.
Let me know your thoughts.
Thanks
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
