07-21-2016, 02:53 PM | #1 |
Doing it the primitive way
I hope it's perfect maybe I'll double check it with the stick
Ya think I'll be dog legging Last edited by Mitch//pa; 07-21-2016 at 04:11 PM. |
07-21-2016, 03:28 PM | #2 |
Re: Doing it the inferior way
Boys with toys..
Good enough.. Isn't. |
07-21-2016, 03:45 PM | #3 |
Re: Doing it the primitive way
we can only wish we had equipment like that....or access to someone who knew how to install it on an A
do I see some custom brackets going on there ?
'31 180A |
07-21-2016, 03:50 PM | #4 |
Is that the KR Wilson 4 wheel alignment tool?
07-21-2016, 03:58 PM | #5 |
Not very sporting!!! But hey, if you've got it, use it
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
07-21-2016, 04:10 PM | #6 | |
adjustable arms to grab the tires... |
07-21-2016, 04:15 PM | #7 |
I'd guess that's a little more precise than my two yardsticks clamped together...
07-21-2016, 04:18 PM | #8 |
I see something is in the red! Is that the camber or toe?
07-21-2016, 04:22 PM | #9 |
07-21-2016, 04:23 PM | #10 | |
Mitch, how much does spoke orientation matter on your set-up? Also, how much would a spoke need to be bent to affect a reading?? |
07-21-2016, 04:31 PM | #11 |
Since the rack does not have the program for a 1930 Model A I punched in a different car, it pulls up the specs for that car and that's why it's red....
I can still see what the readings are and adjust since I know what the specs are for the A I can make a custom vehicle and enter the specs so I can use the bar graphs but I didn't do that yet Last edited by Mitch//pa; 07-21-2016 at 04:44 PM. |
07-21-2016, 04:48 PM | #12 | |
Nothing will affect the reading You do a forward rolling compensation which is approx 4-6" onto the front turntables. That calculates any issues ,,bent wheels etc,,etc.. And compensates for it automatically. The heads do not even need to be centered on the wheels as that is compensated for also..just slap them on and clamp it to the tire treads Last edited by Mitch//pa; 07-21-2016 at 04:54 PM. |
07-21-2016, 05:16 PM | #13 |
It's a wonderful device!
07-21-2016, 06:00 PM | #14 |
Pretty slick !
1/4" toed out. How did it handle ? Did you notice it ? Is there a left camber problem ? Or, is it just a camera shot angle ? |
07-21-2016, 06:34 PM | #15 |
07-21-2016, 07:24 PM | #16 |
Did you buy it @ Harbor Freight & HOW MUCH?
Dad Cheep
07-21-2016, 11:18 PM | #17 |
Been there, done that.
07-22-2016, 05:10 AM | #18 |
07-22-2016, 07:17 AM | #19 |
Ben Hur would have be jealous of those fancy hub caps. Technology has sure brought us a long way, eh?
07-22-2016, 07:31 PM | #20 |
Forgive my ignorance, but what is a "Dubbie Gauge"? I have a home-made curtain-rod gauge that I am pretty happy with, and appears to give me pretty accurate measurements.
Ken
Style beats speed any day, and with a lot fewer tickets. |
