#1 |
Need another timing gear cover for my '36 flathead, are all 21 stud timing covers interchangeable and look the same? The one I currently have has 4 mounting holes for the distributor but distributor only has three mounting bolt holes. There's nothing wrong with the timing cover I have now, I just want another one for a timing pointer that I will install.
#2 |
Could it be that one of the holes is for the vacuum advance?
![]() this is only a hobby! |
#3 |
Could u post a pic of it?
#4 |
Sounds like You have a later cover, is the ditributor flat or helmet shaped?
#5 |
Obviously am not explaining myself well; I just want to get another timing gear cover for my '36 21 stud motor and want to know what other years would work. The three bolt helmet dizzy works fine with the 4 hole timing cover I have now; I just want another cover, don't care if it's 3 holes or four.
#6 |
#7 | |
![]() Quote:
#8 |
You'll care if it's got the wrong BOLT pattern/number.
What you need is another three BOLT timing cover. The two BOLT cover (has two bolt holes and one vacuum hole) won't work for you, your ignition won't bolt on. So, go into the swap meet section and place an add wanting a three bolt timing cover. Martin. I'm pretty much repeating the above post, trying to make it clearer for you. It's all about the bolt holes, don't include the other vacuum hole. |
#9 |
I have some extra '33 to '41 three hole for distributor mounting timing gear covers. If you are interested in getting one, send me a pm for details.
#10 |
Helmet distributor uses a vacuum line not a cover hole???
Three bolt is what ya have wheres the fourth hole ????? You guys got me confused???????????? |
#11 |
You can drill one of the timing cover mounting bolts and fabricate a pointer pin to fit it.
#12 |
No Jim, I'm the confused party here; the cover is three hole and for some reason I thought it was 4 hole, senior moment!
#13 |
#14 |
We have boxes full of NOS 3 bolt timing covers (18-6019) and they sell for $19 each.
#15 |
I still want to see a picture of this 4 bolt cover?
#16 |
#17 |
Check post 3 & 11 on this thread. There was a short lived 4-bolt cover/distributor in 1932.
https://www.fordbarn.com/forum/showth...lt+distributor There were three bolt to two bolt adapters too. |
#18 | |
![]() Quote:
#19 |
The 3-hole dizzy-to-cover gasket actually has four holes in it.......possibly the root of the original confusion. DD
#20 |
Sorry I didn't read all the way through. Junior moment for me haha ( opposite of a senior moment). I had a glimmer of hope that maybe he had uncovered one of the illusive early 32 recalled timing gear covers
