Old 07-08-2016, 10:49 AM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default 21 stud timing cover differences?
Need another timing gear cover for my '36 flathead, are all 21 stud timing covers interchangeable and look the same? The one I currently have has 4 mounting holes for the distributor but distributor only has three mounting bolt holes. There's nothing wrong with the timing cover I have now, I just want another one for a timing pointer that I will install.
36tudordeluxe is offline   Reply With Quote
Old 07-08-2016, 12:04 PM   #2
funrunr
funrunr's Avatar
Default Re: 21 stud timing cover differences?
Could it be that one of the holes is for the vacuum advance?
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
Old 07-08-2016, 12:53 PM   #3
RobR'35
RobR'35's Avatar
Could u post a pic of it?
RobR'35 is offline   Reply With Quote
Old 07-08-2016, 01:31 PM   #4
RalphM
RalphM's Avatar
Sounds like You have a later cover, is the ditributor flat or helmet shaped?
RalphM is offline   Reply With Quote
Old 07-08-2016, 04:29 PM   #5
36tudordeluxe
Obviously am not explaining myself well; I just want to get another timing gear cover for my '36 21 stud motor and want to know what other years would work. The three bolt helmet dizzy works fine with the 4 hole timing cover I have now; I just want another cover, don't care if it's 3 holes or four.
Old 07-08-2016, 05:58 PM   #6
rotorwrench
rotorwrench's Avatar
There was a very early four BOLT distibutor in 1932 but it was recalled due to problems. The one with three bolts and a vacuum port was a later item. All the three Bolt covers will work as long as you have a vacuum supply for the brake appropriate for the distributor you want to use.
Old 07-08-2016, 06:25 PM   #7
36tudordeluxe
That's what I needed to know, thank you.
Old 07-08-2016, 06:27 PM   #8
scooder
You'll care if it's got the wrong BOLT pattern/number.
What you need is another three BOLT timing cover. The two BOLT cover (has two bolt holes and one vacuum hole) won't work for you, your ignition won't bolt on.
So, go into the swap meet section and place an add wanting a three bolt timing cover.
Martin.
I'm pretty much repeating the above post, trying to make it clearer for you. It's all about the bolt holes, don't include the other vacuum hole.
scooder is offline   Reply With Quote
Old 07-08-2016, 06:31 PM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
I have some extra '33 to '41 three hole for distributor mounting timing gear covers. If you are interested in getting one, send me a pm for details.
John
Old 07-08-2016, 07:10 PM   #10
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Helmet distributor uses a vacuum line not a cover hole???
Three bolt is what ya have wheres the fourth hole ?????
You guys got me confused????????????
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-08-2016, 07:38 PM   #11
Randy/In
Randy/In's Avatar
You can drill one of the timing cover mounting bolts and fabricate a pointer pin to fit it.
Randy/In is offline   Reply With Quote
Old 07-08-2016, 08:01 PM   #12
36tudordeluxe
No Jim, I'm the confused party here; the cover is three hole and for some reason I thought it was 4 hole, senior moment!
Old 07-08-2016, 08:04 PM   #13
36tudordeluxe
Read my mind Randy, have a Vern Tardel pointer but am thinking I can come up with something better. Thanks for the suggestion.
Old 07-09-2016, 05:01 AM   #14
Mac VP
Mac VP's Avatar
We have boxes full of NOS 3 bolt timing covers (18-6019) and they sell for $19 each.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 07-09-2016, 09:03 AM   #15
35fordtn
35fordtn's Avatar
I still want to see a picture of this 4 bolt cover?
Old 07-09-2016, 09:20 AM   #16
JSeery
JSeery's Avatar
It doesn't exist! Read post #12.
Old 07-09-2016, 11:17 AM   #17
rotorwrench
Check post 3 & 11 on this thread. There was a short lived 4-bolt cover/distributor in 1932.
https://www.fordbarn.com/forum/showth...lt+distributor
There were three bolt to two bolt adapters too.
Old 07-09-2016, 11:30 AM   #18
JSeery
JSeery's Avatar
Sorry, rotorwrench, I didn't mean to imply they didn't exist, I was referring to the one in question. It was at first stated to be a 4 bolt, but that was a case of mistaken information.
Old 07-09-2016, 11:51 AM   #19
V8COOPMAN
V8COOPMAN's Avatar
The 3-hole dizzy-to-cover gasket actually has four holes in it.......possibly the root of the original confusion. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-09-2016, 11:57 AM   #20
35fordtn
35fordtn's Avatar
Sorry I didn't read all the way through. Junior moment for me haha ( opposite of a senior moment). I had a glimmer of hope that maybe he had uncovered one of the illusive early 32 recalled timing gear covers
