Old 04-10-2016, 02:16 PM   #1
Ziffer
Default Need Help...No cone in front Wheel Cylinder to seat hose fitting
I am installing my front wheel cylinders (39-41 Lincoln) and there is no little cone down in the hole for the brake hose taper to seat against??? I read a post on another site that said you can buy the little cone and put it in but both of my local parts stores can't find anything. Can I buy just the cone? What is the proper name for it?
Thanks in advance for your help.
Z
Ziffer is offline   Reply With Quote
Old 04-10-2016, 02:41 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Need Help...No cone in front Wheel Cylinder to seat hose fitting
Contact these folks. Their website says 32 to 38 but they are extremely knowledgeable.
http://www.earlyv8garage.net/
19Fordy is online now   Reply With Quote
Old 04-10-2016, 02:46 PM   #3
TJ
TJ's Avatar
Z
I'm no expert on Lincoln brakes, but some wheel cylinders do not have the seat(cone) in them. On some the hose seats down on a copper washer on the outer flat surface of the cylinder. F-100 brakes are an example.
Old 04-10-2016, 03:01 PM   #4
flatheadfan
flatheadfan's Avatar
Another knowledgeable source is: Brake Hosees Unlimited. Ask for Nick. Super helpful and very reasonable.
Tom
flatheadfan is offline   Reply With Quote
Old 04-10-2016, 04:26 PM   #5
42merc
42merc's Avatar
I don't believe any front wheel cylinder relies on a tapered seat for a seal.
The hose will use a copper washer to make the seal.
42merc is offline   Reply With Quote
Old 04-10-2016, 05:12 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Yep, that's all I recall on the front brakes.
Old 04-10-2016, 05:26 PM   #7
grovesmr
I just redid the entire brakes on my 35 with 39 brakes. As mentioned above, the seal on the front cylinders is made with copper washers between the flex line and wheel cylinders. No hard line there to need a seat. I'm not using Lincoln brakes but if you aren't running a hard line into the cylinder I see no reason to need that seat.
grovesmr is offline   Reply With Quote
Old 04-10-2016, 06:25 PM   #8
Kube
Kube's Avatar
You are correct.
