Old 02-08-2015, 08:22 PM   #1
mollydog
Default Valve Adjustment on a Miller head
I just got my 30' Tudor running. It had a Miller Hi-Speed head installed (OHV conversion). I checked the valve clearances and set them at .012 as recommended. With the engine running there is a lot of Clackety-clackety noise like the valves are too loose! Does anyone have experience with this setup and what valve clearance do you recommend? The engine runs fine otherwise.
Mollydog
mollydog is offline   Reply With Quote
