I am looking for a "How to" or someone to rebuild a '32 steering drop. Mine has a missing key and the lever is broken off. Thanks for the help.
I think Baxter's Ford Parts ((785) 842-9256) has someone that rebuilds them. Even if you do it yourself they might be a good source of parts.
Charlie Stephens |
Use the Forum Search -- lots of prior posts-- some with pictures diagrams
I tried this first and come up empty. |
Firerod,
Try these: https://www.fordbarn.com/forum/showthread.php?t=131885 https://www.fordbarn.com/forum/showthread.php?t=103694 https://www.fordbarn.com/forum/showthread.php?t=106803 https://www.fordbarn.com/forum/showthread.php?t=70177 https://www.fordbarn.com/forum/showthread.php?t=67226 https://www.fordbarn.com/forum/showthread.php?t=66031 https://www.fordbarn.com/forum/showthread.php?t=65197 https://www.fordbarn.com/forum/showthread.php?t=62108 https://www.fordbarn.com/forum/showthread.php?t=57747 Hope these help. ![]() Keep V-8ing and 4-banging!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
#7 | |
http://www.ebay.com/itm/1932-Ford-St...#ht_340wt_1363 I don't think the concentric circles in the head are correct, but good enough for me... EDIT: I now see a second version that looks to be more correct in the concentric circles... http://www.ebay.com/itm/1932-Ford-Ig...#ht_279wt_1363 Neal Last edited by NealinCA; 10-21-2014 at 01:19 PM. |
#8 | |
Paul J. |
Is the seller someone on here who would sell directly? The circles are maybe a touch too sharp, but a whole lot better than the broken stump I have on one drop!
#10 | |
Shows 3 pages of threads 5 pages of posts Try different words -- its there --lots to find and read Luck Gene |
Thank you Jersey Boy.
Jersey Boy:
Thanks for demonstrating the advantage of being more specific in the use of the Forum Search tool. I learned from your posting! Excellent! Still learning @ 73--having fun. Thanks again. Gene Tulsa |
#13 |
Bruce - I know the guy in the second version posted and have seen them in person. Very nice quality and attention to detail. If interested, PM me and I'll put you in touch with him.
#14 | |
I have created files in my "User CP". These files are divided up into topics. One of the topics is 32 Ford. At the top of the thread, ie... 32 Steering column drop rebuild, there is a section called "Thread tools" I click on that and select subscribe. I will always be updated on the progress of this "subscribed thread", and it will be stored in my files. I simply went into my files and selected the threads about column drops. Keep V-8ing and 4-banging!
#15 | |
Threads will be added after you subscribe ?-- What would it take to pull up prior threads? Trying to hang on to 21st century technology I'll try to get with it. Gene Tulsa Oh---Senior Post. Last edited by G32; 10-22-2014 at 01:03 PM. |
#16 | |
Look at the red bar at the top of this thread...See were it says thread tools. Click on that and a list of options appear. Click on the one that says subscribe. The screen will change and it will ask you if you want to subscribe, click subscribe. If you look at the black bar near the top of the regular page, you will see User CP. Click on that, and all the threads that you have picked and have current posts will show. If they do not show, look to the left and there is a list of topics, scroll down and pick subscriptions. Keep V-8ing and 4-banging!
#17 | |
My '32 lever is cast from a very nice original. The concentric circles are factory. My lever is cast in bronze and plated in nickel which is also correct. They are not machined or manufactured so to speak. The lever is heavy and far more durable than the original. My lever even has the indentation inside where the small spring sits should you happen to still have it. If you don’t have it, you won’t need it. Price is $50.00 plus shipping. I have finally finished my reproduction of the ON/OFF escutcheon. I am completing them in small batches right now. They are also cast from an excellent original. They are plated in the same nickel and hand painted and finished one at a time. The borders and edges are raised as per original. The switch plate will slide over your existing lever as it should; unlike the stamped version. They are already shaped to fit your column drop so they are hassle free to install as long as you can see well enough to tap in the rivets! Several '32 aficionado’s and experts agree that it is an excellent reproduction. These are $75.00 ea. plus shipping. Thanks for your interest. I can be reached at [email protected]. They will be listed on eBay again shortly. Chad |
#18 |
Both his lever and ON/OFF plate are outstanding reproductions. The lever is also correct for early '35s.
