#1 |
Hey guys. I have been looking for a source to get a replacement ignition cylinder and hurd keys for stock '32 column drop. I have also been looking for a replacement ignition switch (the chrome part on the front). Does anyone reproduce these? Any help would be appreciated.
Jim
1932 Ford 5 Window 1932 Ford Roadster |
#2 |
I don't believe anyone is commercially making that switch lever but if someone knows otherwise I would also be interested in finding out. On the lock cylinder, I would suggest not using a reproduction part. Find and use an original cylinder even if it must be repaired and/or re-keyed. JMHO
#3 |
Basic cylinder swaps from '32-35...maybe '36, don't have ctalog here. Most original cylinders will revive with just a thorough cleaning...they are normally full of grit.
A drop specialist on the HAMB made a few levers from stainless some years back but I think he has not done another run...they were functional replacements, not truly repros, and could have been worked into a pretty close visual repro. |
#4 |
Gentlemen, I would check with Jim Kroll in Ohio. He has had a few cylinders listed either here or on the Early Ford site. www.efv8.org They may have been for doors etc.....can't remember!
Pat |
#5 | |
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 03-14-2012 at 11:19 AM. |
#6 |
#7 |
Jim, thanks for the tip. I am interested in getting on his list to buy some of these. I would very much appreciate a pm from you on how to get in touch with him so I could discuss some details and also get my name on his list. Thank you!
#8 |
32 -35 Ign. cylinders were similar but not exactly the same. 32 and some 33 cylinders were polished on the face and had a small locking pin on the rear that acted as a detent. the later ones 34-35 did not have that pin and had a brushed chrome face. I just cut some keys for later cylinders for a friend and they were bare brass on the face. Also last week I purchased a near new 32 cylinder with matching HURD key for $135.00 from Ebay. Soooo ......real 32 cylinders are tough to find and pricey. Hope this helps.
Early Ford Lock & Key Service https://www.fordbarn.com/forum/showthread.php?t=46583 |
#9 |
Jim, I'll be interested in a few of those levers. Let me know, please!
Phil, I have a bunch of stuff to send you when I get it organized. Z
WANTED: 1932 Front X-Member 1932 Rumble Seat Back Spring Cushion- Roadster 32-34 Roadster Windshield Cones Original 32 Straight Rear Spreader Bar |
#10 |
Thanks guys for the information.
