Old 05-08-2026, 08:28 PM   #32
Gary WA
Gary WA's Avatar
Default Re: No Spark - NEED HELP! UPDATE
Originally Posted by sconnors View Post
Still not starting. New ignition switch and new ignition cable installed. Car just cranks. When I pull the coil wire and turn the engine, I have spark jumping from the wire to the head. When I pull a plug and turn the engine over, I have spark at the plug. As suggested by someone on the Ford Barn, I even tried spraying a little starter fluid in the cylinder before I put the plug back in and it still didn’t fire.
Here are the current voltages:
Key off:
• Starter (red) 6.28
• Starter (black) 6.28
• Coil + 6.25
• Coil – 6.25
• Points open 0.03
• Points closed 0.03
Key on:
• Starter (black) 6.05
• Coil + 0.30
• Coil 5.64
• Points open 6.22
• Points closed 0.16
ANY INPUT WOULD BE GREATLY APPRECIATED.
Are you sure the dizzy Pigtail is not shorting out??? Sure you have gas to the carb!!!!! Spray carb! see if starts! with key on are you getting a spark by opening and closing the points with small screw driver etc?? at the points??!
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
