#21 | |
The car had been running great and driving on long distances fine. I parked if, didn't run it for a day, went out to go to the show, it started and ran for like two seconds and died, I started it again and it ran for two seconds and died and now just cranks over. Thanks for your input, I'll post the results later today when I go home. |
#22 |
Is the under dash gas valve turned on?
#23 |
#24 |
Hello, a lot of good advice here, when I have electrical problems, the condenser is usually the first suspect, but you have checked that , next is the wire that connects the points on upper plate to the lower plate, wire can loosen or break because it moves with spark rod control. Ignition switch contacts also can be a problem,also is you have a known good coil you may want to change to it . As a long time Model A enthusiast found,unfortunately, just because it’s a new part doesn’t mean it’s good. Good luck,and don’t give up!!
#25 | |
I'll keep plugging away. |
#26 |
Bob |
#27 | |
#28 | |
Have you disconnected the fuel line from the carburetor, swing it back away from the carburetor, opened the gas valve inside the car under the tank, and confirmed that fuel flows in a good steady stream out of the fuel line? "Runs for a few seconds and then dies" is usually fuel related.
Jim Cannon Former MAFCA Technical Director ![]() "Have a Model A day!" |
#29 | |
I'll double check the gas. My car's battery is positive to ground, I will double check the coil connections tonight when I get home. |
#30 |
hotwire following this diagram to help locate any wiring fault. But since you say "With the key on if I open and close the points by hand there is spark " I would supsect a fault at the points/rotor.
#31 |
Was able to speak with a very knowledgeable Model A friend and we did some testing and think we have it narrowed down to the ignition cable being faulty. I've ordered one and will keep you guys posted!! Much thanks!
#32 |
If you screwed the cable into the base of the distributor too far, it can short out things inside. You may be able to fix it by just unscrewing the cable a turn or two.
#33 |
Engine at TDC is not where you adjust the points gap. It is where the points open. Look at the points cam follower to make sure it is at the top of a lobe, then check/adjust.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#34 |
Still not starting. New ignition switch and new ignition cable installed. Car just cranks. When I pull the coil wire and turn the engine, I have spark jumping from the wire to the head. When I pull a plug and turn the engine over, I have spark at the plug. As suggested by someone on the Ford Barn, I even tried spraying a little starter fluid in the cylinder before I put the plug back in and it still didn’t fire.
Here are the current voltages: Key off: • Starter (red) 6.28 • Starter (black) 6.28 • Coil + 6.25 • Coil – 6.25 • Points open 0.03 • Points closed 0.03 Key on: • Starter (red) 6.28 • Starter (black) 6.05 • Coil + 0.30 • Coil 5.64 • Points open 6.22 • Points closed 0.16 ANY INPUT WOULD BE GREATLY APPRECIATED. |
#35 | |
www.whidbeymodelaclub.com Last edited by Gary WA; 05-08-2026 at 08:36 PM. |
#36 |
You checked the wire under plate it may look good BUT it could be grounded to body of dizzy??!! Why did you replace the top plate??
www.whidbeymodelaclub.com |
#37 | |
Sounds like you have checked everything else. |
#38 |
With the key on I’m getting spark when opening and closing the points and there is gas to the carb
#39 |
#40 |
I had the engine at tdc and used the NU-Rex timing wrench and set the point gap at 22
