Old 03-16-2022, 09:23 AM   #1
bismark
Default HOLLEY 885F vs 1901FF CARBURETOR
Hello there, can anyone tell me why an aluminum bowl cover plate is used on the 885F along with 2 bowl gaskets, but the 1901FF , which shares the same fuel bowl does not ?
bismark is offline   Reply With Quote
Old 03-16-2022, 09:54 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: HOLLEY 885F vs 1901FF CARBURETOR
They are two different design carburetors and don't really share anything.
And if one has two gaskets and the other does not, that is the way each was designed.
Old 03-16-2022, 10:27 AM   #3
bismark
Hi there, actually i have both carbs, and have carefully inspected both, and the fuel bowls are identical, the bowl covers are different, but for some reason the 885 uses a metal plate between the top and the bowl.
Old 03-16-2022, 10:38 AM   #4
34PKUP
34PKUP's Avatar
What about '2 different designs' don't you understand?
34PKUP is offline   Reply With Quote
Old 03-16-2022, 11:03 AM   #5
bismark
So tell me then, what is the purpose of the metal plate in the 885F ??
Old 03-16-2022, 11:41 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
It is a metering plate that regulates the air/fuel mixture under certain throttle conditions.
The size of the metering holes depend on which engine (Merc. or Linc.) the carb. is being used on.
Old 03-16-2022, 11:56 AM   #7
bismark
Thank you 51 MERC-CT, i appreciate that answer, unlike 34PKUP who felt the need to post a sarcastic reply, which was intended to suggest that i was stupid.
Old 03-17-2022, 08:51 AM   #8
rotorwrench
rotorwrench's Avatar
The air shroud on the 885 is also the cover for the float bowl. The shroud also has the power valve operating mechanism and vacuum circuit installed in it. It does have multiple differences from the 1901. There are Holley parts break downs than can be found online that illustrate the differences.
Old 03-17-2022, 10:51 AM   #9
scicala
scicala's Avatar
The thin plate between the gaskets was for the main well air bleeds. The 885F was the first teapot design carb, and that's just the way they did it at first.
Sal
scicala is offline   Reply With Quote
Old 03-20-2022, 03:30 PM   #10
bismark
Thank you Sal. I rebuilt a 1901F for a customer, and had a heck of a time getting the pump to work properly due to warpage between either the bowl and/or the bowl cover. If there is not a firm tight mating , then the pump wont work properly. I went through about 5 used cores before i found a bowl cover that wasnt warped. I was wondering if that metal plate could be used on a 1901F to eliminate a gap due to warpage, if a suitable bowl cover couldnt be found ???
Old 03-20-2022, 09:14 PM   #11
rotorwrench
I've had the same problems on my Mercury cars with the 885. Heavy handed or careless shade tree mechanics likely tried to "fix" a lot of these back in the day.
Old 03-22-2022, 05:22 PM   #12
scicala
scicala's Avatar
The bowl covers on 1901 Holley carbs and later teapot 2 and 4 barrel carbs are pretty thin die cast zinc and easy to make flat again. Not so on the 885F's though, which don't really warp..
I don't think the thin plate will work right on a 1901, plus it won't really cure the warped cover problem or seal. It's very easy to carefully bend the sagging corners up again. Then don't over tighten when assmbling.
Sal
Old 03-24-2022, 12:21 PM   #13
bismark
How would you recommend bending the corners back in line with air horn, to be flat again ?
Old 03-24-2022, 06:01 PM   #14
scicala
scicala's Avatar
With the cover inverted, carefully tap three of the four corners down (with a rawhide or nylon mallet). The 4th corner by the accel pump doesn't sag.
You can even go a little above flush, since it will straighten out when you tighten the screws, and help seal the gasket better.
Sal
Old 03-24-2022, 08:14 PM   #15
bismark
Thanks sal!
