#15 |
If you have bled out all the air and still have a low pedal, then its a mechanical issue and not about bleeding. Could be the shoes are still too far from the drum, or the free play on the activator rod off the pedal is not adjusted correct, or even the home made pedal travel ratio is incorrect.
