Old 02-10-2018, 04:34 PM   #1
cretin
cretin's Avatar
Default Lever shock rebuild parts
Hey guys,
I've got these shocks I'm planning on using on a current project. It is my understanding that these shocks were used from'38-'48.
I've found info on rebuilding, but not any info on where you can get parts and/or seals.
Please understand, I am not looking for a rebuilding service, I am going to deal with these myself. This is a budget project, and my labor is cheap.
So, I was wondering if anyone knew where I can get seals or anything else for these before I open them up and start figuring it out. Thanks!
cretin is offline   Reply With Quote
Old 02-11-2018, 01:03 AM   #2
Lawrie
Lawrie's Avatar
Default Re: Lever shock rebuild parts
The ones I fixed up and used on my 33 and 34 I modified the end cap to seal on the body with an o ring and machined it to accept a modern hydraulic seal.easy, they dont leak.
Lawrie
Old 02-11-2018, 02:32 AM   #3
cretin
cretin's Avatar
That's a good idea. I'll keep that in mind.
Thanks
Old 02-11-2018, 09:29 PM   #4
atch
atch's Avatar
Hello folks. If you look at my profile you'll see that I very seldom post. But I come and try to read/learn.
I've been searching (Google, here, the H.A.M.B., etc.) for years to find information on how to rebuild these things and to find out why it's so expensive to get yours rebuilt.
So Ill be the first to admit that old guys like me aren't as good or savvy on the computers as some of you are. Maybe cretin or someone else on here would share the information on how to rebuild these.
Thanx.
atch (Mike Atchley)
Columbia, Missouri
atch is offline   Reply With Quote
Old 02-11-2018, 10:49 PM   #5
JSeery
JSeery's Avatar
Lawire posted quit a bit of information and photos when he was rebuilding his. You should be able to find them using search.
Old 02-12-2018, 02:41 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
First you have to get the arm off ----you need a very good puller
Old 02-12-2018, 04:55 AM   #7
Lawrie
Lawrie's Avatar
easy to make one ,after you see the one in the infp from houdail.
Can post a pic if ypu want tomorrow.
Lawrie
Old 02-12-2018, 04:58 AM   #8
FortyNiner
FortyNiner's Avatar
The 1942-1948 Ford Shop Manual has info and illustrations on shock rebuilding.
Old 02-13-2018, 11:58 PM   #9
atch
atch's Avatar
Thanx for the links. I've got a lot of studying to do now.
atch (Mike Atchley)
Columbia, Missouri
Old 02-14-2018, 01:34 PM   #10
grumppyoldman
grumppyoldman's Avatar
My front shocks had been re-built when I got the car, I cleaned up the rear ones, filled with oil and have no leaks yet. Might try that first to save cost. Al
grumppyoldman is offline   Reply With Quote
Old 02-14-2018, 02:36 PM   #11
Seth Swoboda
Seth Swoboda's Avatar
I'd like the link to Lawrie's thread on rebuilding his own shocks. Did not see it in my initial search.
Old 02-19-2018, 05:37 PM   #12
cretin
cretin's Avatar
Thanx.
Sorry, I've haven't been on here for a bit. Here is a manual I got a link to off this site for rebuilding.
http://www.oldcarmanualproject.com/m...e%2000_jpg.htm
Old 02-20-2018, 12:05 AM   #13
VeryTangled
VeryTangled's Avatar
Hi Everyone. Seth I tracked down Lawrie's threads on shocks:
https://www.fordbarn.com/forum/showthread.php?t=181563
https://www.fordbarn.com/forum/showthread.php?t=182259
https://www.fordbarn.com/forum/showthread.php?t=181635
https://www.fordbarn.com/forum/showthread.php?t=181638
https://www.fordbarn.com/forum/showthread.php?t=180167
-Jeff H
Old 02-20-2018, 10:00 AM   #14
Seth Swoboda
Thanks Jeff!
Old 02-24-2018, 11:59 PM   #15
cretin
cretin's Avatar
So do rebuild parts not exist?
Or am I left to my own devices?
Old 02-25-2018, 11:35 AM   #16
rotorwrench
rotorwrench's Avatar
Houdaille used to sell kits with all the hard and soft parts and their service bulletin #18080 gave all the instructions. Now days, it's very important to find the best core shocks you can. There are no new hard parts to be had that I'm aware of so it's critical that they be in good condition. Most rebuilders find the nearest to correct soft parts that are available and make them work the best that they can.
Bill Wzorek used to be our resident shock man but health problems forced him to turn his business over to someone else that doesn't frequent this site. A few of the folks still do their own but I don't know what they use for soft parts. If you look at the Houdaille SB-18080 in the old car manual project, you can see the differences that are out there between the early type shocks and the later ones. Another problem is that there were some aftermarket manufacturers out there so it is important to get the real "Who-Die" shocks.
rotorwrench is online now   Reply With Quote
Old 02-26-2018, 10:53 AM   #17
corvette8n
corvette8n's Avatar
Bill Wzorek passed the torch of shock rebuilding to his friend Andy Falandesso. Give Andy a call, his cell phone number is: 413-768-8487 and his email is: [email protected]
You may be able to get part from Andy.
Old 02-26-2018, 03:23 PM   #18
cretin
cretin's Avatar
Ok great. Thanks guys.
