Old 03-01-2016, 05:32 PM   #9
SeaSlugs
SeaSlugs's Avatar
Default Re: Door Latches for 1929 Closed Cab PU
Originally Posted by fiftyv8 View Post
Talk to Steve at Bert's Model A Center.
I had reason to advise Steve about 6 months ago of a small issue with some Repro latches.
I forget the exact issue but I am sure Steve will recall as he was going to contact the Maker to have it corrected.
What I do recall is that Steve said there are two Makers of latches.
So best talk to him first and he also sells them.
Restoring old latches is slow if you need parts and buying restored latches from say ebay does not guarantee that they are done well.
One restored latch I purchased from ebay a good number of years ago turned out to be missing the internal lock mechanism gismo, try and find one of those suckers.
I borrowed one and hand copied it - what a job.....
Also when opening the old latches up, you must be careful not to break the tags off.
ive got 5 latches in various conditions and they all seem to be severely worn in the same few spots, going to take ALOT of careful welding to get the latch pivot holes back round... if its even possible.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
