Old 08-20-2012, 12:16 PM   #201
sturgis 39
Default Re: F150 tranny with overdrive
Originally Posted by Kahuna View Post
In my 32, I put a 4 speed toploader and a Gear Vendors OD. 8 forward speeds
Kuhuna
Could you explain and show pictures of a gear vendor overdrive? I have not heard of a gear vendor over drive.
Thanks
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 08-20-2012, 12:37 PM   #202
1931 flamingo
1931 flamingo's Avatar
Gear Vendor is the manuf.
Paul in CT
Old 08-20-2012, 12:44 PM   #203
sturgis 39
Paul in CT
That reply was kind of vague. Is the overdrive a bolt on to the transmission or did they build the whole unit which includes the transmission and overdrive unit. I am still confused.
Old 08-20-2012, 01:05 PM   #204
Bob C
They come either way. They have adapters to bolt them to the back of the transmission or
they can be put in the drive line.
Link http://www.gearvendors.com/custom.html
Bob
Old 08-20-2012, 01:39 PM   #205
sturgis 39
Bob
Thanks for the reply. I went to the site and I seem to be having trouble navigating to the right location. I will have to return to the site again.
Thanks
Old 08-20-2012, 02:19 PM   #206
Kahuna
Kahuna's Avatar
Gear Vendors makes all kinds of stuff. Generally, they make adapters so that an O/D can be added to some or all of the most popular transmissions (Std and automatics). I think they also now do an in-driveshaft O/D for Model A's and early V8 Fords.
Keep in mind that Gear Vendors owns all the stuff that was originally the Laycock-De-Normanville Overdrive (Volvo, Austin Healey, Triumph, etc.).
Jim
Kahuna is offline   Reply With Quote
Old 08-20-2012, 03:12 PM   #207
Kahuna
Kahuna's Avatar
Here are a few pictures. The transmission is a Jeep Aluminum case, fitted with Ford gears (yes, they fit w/out modification). Then an adapter was made to connect the O/D to it.
The shifter top assy is also Jeep and I used a Marlin model 66 gun barrel to be able to run the wires from the shift ball. The ball is from a Volvo and has the switch in it to trigger a set of relays to engage the O/D
Old 08-20-2012, 03:19 PM   #208
miss victoria
very nice looking job!!!
miss victoria is offline   Reply With Quote
Old 08-20-2012, 04:08 PM   #209
Kahuna
Kahuna's Avatar
Thank You
I've got about 750 miles on the car now. The O/D functions well. I'm running a 4.11 rear axle, and in O/D it equates to a 3.20
Jim
Old 08-20-2012, 04:47 PM   #210
Crazydaddyo
Crazydaddyo's Avatar
Here is the T-5 with a closed drive line in a stock A chassis
Crazydaddyo is offline   Reply With Quote
Old 08-20-2012, 04:49 PM   #211
miss victoria
another nice looking conversion!!
Old 08-20-2012, 05:53 PM   #212
sturgis 39
I appreciate the pictures and the information. I am going to have a wait for a while to do something. I kind of like Dave's the best right now.
Thanks Again
Old 08-22-2012, 04:13 AM   #213
wensum
wensum's Avatar
The photos show a bell housing adaptor made in New Zealand by Mac's Speed shop and sold in the States. (I don't know who by)
This alloy casting includes the shaft for the clutch forks and pedals left or right hand drive
It is a simple bolt-on job for the F150 gearbox, but because the input shaft spline starts further back than the Model A one, a special offset clutch plate has to be made.
In this installation, there is also a quick change rear end and consequently there is also an open prop shaft
wensum is offline   Reply With Quote
Old 08-22-2012, 09:17 AM   #214
miss victoria
That is a nice bellhousing, saw one at a swap meet the vendor had a price tag $395.00 did not notice is there a mount on the bottom for the wishbone?
Old 08-22-2012, 02:28 PM   #215
Jim Parker Toronto
Jim Parker Toronto's Avatar
Yes.........
Jim Parker Toronto is offline   Reply With Quote
Old 07-13-2015, 06:51 PM   #216
spdway1
spdway1's Avatar
Who is NOW building these transmissions and that are RELIABLE. Dave's Delhume site is down again. I can't get in contact with him.
spdway1 is offline   Reply With Quote
Old 07-13-2015, 07:15 PM   #217
a-bone newby
a-bone newby's Avatar
I have a model a and want to keep it as stock as possible if I want race I would buy a lamborgini I am not trying to be cheeky but why a A if not to put around han have people admire my car stock?
a-bone newby is offline   Reply With Quote
Old 07-13-2015, 08:14 PM   #218
CarlG
CarlG's Avatar
Originally Posted by spdway1 View Post
Who is NOW building these transmissions and that are RELIABLE. Dave's Delmue's site is down again. I can't get in contact with him.
I just went to his site and it came right up:
modelaonly.net
Contact info on his website:
Dave Delmue
17649 Peak Ave.
Morgan Hill, CA 95037
408-722-2518
Email: [[email protected]]
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-14-2015, 07:44 PM   #219
spdway1
spdway1's Avatar
You can use your Model A to go apple picking and it is your car to do what ever you please. We use ours to race (nostalgia hill climbs and such). It is not a hot rod by any means. Just looking for a transmission that will do the job! Any suggestions?
Second place is the first looser!
Old 07-14-2015, 09:07 PM   #220
1929
You had me laughing spdway, that was good, (go apple picking)
1929 is offline   Reply With Quote
