#201 | |
![]() Quote:
Kuhuna Could you explain and show pictures of a gear vendor overdrive? I have not heard of a gear vendor over drive. Thanks
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
#202 |
Gear Vendor is the manuf.
Paul in CT |
#203 |
![]() That reply was kind of vague. Is the overdrive a bolt on to the transmission or did they build the whole unit which includes the transmission and overdrive unit. I am still confused.
#204 |
They come either way. They have adapters to bolt them to the back of the transmission or
they can be put in the drive line. Link http://www.gearvendors.com/custom.html Bob |
#205 | |
![]() Quote:
Thanks for the reply. I went to the site and I seem to be having trouble navigating to the right location. I will have to return to the site again. Thanks
#206 |
Keep in mind that Gear Vendors owns all the stuff that was originally the Laycock-De-Normanville Overdrive (Volvo, Austin Healey, Triumph, etc.). Jim |
#207 |
Here are a few pictures. The transmission is a Jeep Aluminum case, fitted with Ford gears (yes, they fit w/out modification). Then an adapter was made to connect the O/D to it.
The shifter top assy is also Jeep and I used a Marlin model 66 gun barrel to be able to run the wires from the shift ball. The ball is from a Volvo and has the switch in it to trigger a set of relays to engage the O/D |
#208 |
very nice looking job!!!
#209 |
Thank You
I've got about 750 miles on the car now. The O/D functions well. I'm running a 4.11 rear axle, and in O/D it equates to a 3.20 Jim |
#210 |
Here is the T-5 with a closed drive line in a stock A chassis
#211 |
another nice looking conversion!!
#212 |
I appreciate the pictures and the information. I am going to have a wait for a while to do something. I kind of like Dave's the best right now.
Thanks Again
#213 |
Model A adaptors 005.jpg Model A adaptors 006.jpg The photos show a bell housing adaptor made in New Zealand by Mac's Speed shop and sold in the States. (I don't know who by) This alloy casting includes the shaft for the clutch forks and pedals left or right hand drive It is a simple bolt-on job for the F150 gearbox, but because the input shaft spline starts further back than the Model A one, a special offset clutch plate has to be made. In this installation, there is also a quick change rear end and consequently there is also an open prop shaft |
#214 |
That is a nice bellhousing, saw one at a swap meet the vendor had a price tag $395.00 did not notice is there a mount on the bottom for the wishbone?
#215 |
#216 |
Who is NOW building these transmissions and that are RELIABLE. Dave's Delhume site is down again. I can't get in contact with him.
#217 |
I have a model a and want to keep it as stock as possible if I want race I would buy a lamborgini I am not trying to be cheeky but why a A if not to put around han have people admire my car stock?
#218 | |
![]() Quote:
modelaonly.net Contact info on his website: Dave Delmue 17649 Peak Ave. Morgan Hill, CA 95037 408-722-2518 Email: [[email protected]]
#219 | |
![]() Quote:
Second place is the first looser! |
#220 | |
![]() Quote:
