Old 01-18-2015, 08:29 PM   #1
glenn in camino
glenn in camino's Avatar
Default B block
I have a B block that's cracked under the inserted valve seats and perhaps somewhere else. Can it be repaired or should I buy a boat that needs an anchor?
Old 01-18-2015, 08:37 PM   #2
quickchange
quickchange's Avatar
Default Re: B block
Have 3 more here, attempt was made by the pros to repair one but still leaks under pressure. Maybe able to use with OHV set up , maybe, Turn the temp dow in NZ ,
quickchange is offline   Reply With Quote
Old 01-18-2015, 08:52 PM   #3
verdirick
Default Re: B block
I have a duplicate in the garage. I would contact Art Moore in Upland Ca. 909-982-7790([email protected]). I anyone out there can fix it, he is the one...I'm still waiting to send him photos of mine. Found another block so I'm in no hurry to spend the money on this one.
verdirick is offline   Reply With Quote
Old 01-18-2015, 10:01 PM   #4
edmondclinton
Default Re: B block
They are quite a ways from CA. but J&M Machine in South Borough MA. are experts at such a repair.
edmondclinton is offline   Reply With Quote
Old 01-18-2015, 10:34 PM   #5
colin1928
colin1928's Avatar
Default Re: B block
I have repaired a few B blocks with mixed results 50/50 just too thin or weak
if it was an A block or 8BA 99.9% success repair rate
colin1928 is offline   Reply With Quote
Old 01-18-2015, 11:13 PM   #6
Pete
Default Re: B block
Anything can be fixed so it is like new.
If you don't want to spend what it takes, there may be some new blocks
come along if you wait long enough.
Old 01-19-2015, 12:15 AM   #7
tbirdtbird
Default Re: B block
ppl need to not be in such a rush to use valve seats on As and Bs.....this often leads to cracks....
'31 180A
tbirdtbird is offline   Reply With Quote
Old 01-19-2015, 01:41 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: B block
I agree with Tbird and would never install a seat unless the original was very recessed, and even then an oversized valve might be a better way to go.
Old 01-19-2015, 01:26 PM   #9
ursus
Default Re: B block
He has a B-block so it already had inserted valve seats the day it left the factory. I wonder if he is referring to the "roof" area of the valve chamber where B-block are notorious for developing cracks.
ursus is online now   Reply With Quote
Old 01-19-2015, 01:42 PM   #10
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Default Re: B block
Yes it can be repaired and i would suggest taking it to a machine shop that can magnaflux and pressure test block.
Model B's are more prone to cracking.
Lock n Stitch is in Turlock,CA and can do the above mentioned repairs.
If you were on our side of the country it's a relatively frequent repair.
www.jandm-machine.com
J and M Machine is offline   Reply With Quote
Old 01-19-2015, 03:37 PM   #11
Fullraceflathead
Fullraceflathead's Avatar
Default Re: B block
Amazing Repair!
Fullraceflathead is offline   Reply With Quote
Old 01-20-2015, 07:19 PM   #12
tbirdtbird
Default Re: B block
"He has a B-block so it already had inserted valve seats the day it left the factory."
not a true statement
'31 180A
Old 01-21-2015, 12:58 PM   #13
mngreen
mngreen's Avatar
Default Re: B block
Just throw on an OHV conversion if there's more than one crack. It won't care all the valve seats in the block are shot!
......and double your HP in the process!
mngreen is offline   Reply With Quote
Old 01-22-2015, 05:41 PM   #14
Synchro909
Synchro909's Avatar
Default Re: B block
Doesn't stop the crack growing. I'd get it repaired, then put the OHV head on it. Overkill maybe but I prefer to drive than walk.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
