Old 08-02-2016, 09:10 AM   #1
nbrskn
Default canister oil filter
where do you guys get the original filter for your engines ?
or perhaps a conversion inside the original
nbrskn is offline   Reply With Quote
Old 08-02-2016, 09:19 AM   #2
ford38v8
ford38v8's Avatar
Default Re: canister oil filter
Fram C4P is available at most auto supply stores.
Alan
Old 08-02-2016, 10:25 AM   #3
tubman
tubman's Avatar
For filters for my '51, I usually go to NAPA and buy their house brand, "NAPA Gold". I hear they are made by "Wix" and are of a high quality. Every time I went to NAPA to buy one, they had them in stock.
Speaking of Fram filters, I have read on the H.A.M.B. they have a bad reputation for being cheaply made and are prone to falling apart. This may be on the "spin-on" filters only. Does anyone know if this pertains to the cartridge filters as well? I ask because I bought a couple on closeout from Rock Auto last winter for a a very good price, but am kind of reticent to use them.
Old 08-02-2016, 10:52 AM   #4
Ronnie
Ronnie's Avatar
Atlas G-60
-Shell S-5
-Texaco T-5
-Union Oil P-115
-A.C. P-115
-Purolater P-51
-Fram C-4
-NAPA gold 1004
-Motorcraft - FL25
-Wix - 51006
-Hastings LF-101
-Baldwin p41
-51503 wix 8"long
-lf106 Hastings 8"long
R
Ronnie is offline   Reply With Quote
Old 08-02-2016, 01:43 PM   #5
RalphG
RalphG's Avatar
I've used fram oil filters in a wide range of vehicles and equipment for years and never a problem with any of them. I've heard some comments as to their being inferior quality but have never seen any evidence of it. Same with Champion spark plugs.
I've got a "Varcon" oil filter in the 52 Merc. Bet nobody remembers them.
RalphG is offline   Reply With Quote
Old 08-02-2016, 11:08 AM   #6
OLD AS I
OLD AS I's Avatar
Is there only one canister for all flat heads regardless of the year, so any year flat head if it has a canister filter system they are all the same ?
OLD AS I is offline   Reply With Quote
Old 08-02-2016, 12:57 PM   #7
JSeery
JSeery's Avatar
The year of the engine wouldn't matter, it would be the year of the filter. The by-pass filter is a removable part and an add-on accessory on many years. Like almost all removable part you can find any year on about any year!! That said, in general they are all the same.
Old 08-02-2016, 01:12 PM   #8
Ronnie
Ronnie's Avatar
The canisters generally are all the same but there are dimension differences between some cartridge mfg's. Nothing to be overly concerned,they will work but they aren't identical.That application has been in catalogues for so long that any mistakes would have been discovered and corrected long ago.
R
Old 08-02-2016, 03:14 PM   #9
Kube
Kube's Avatar
40 - 48 is different than 49 - 53. They will not interchange.
Old 08-02-2016, 04:57 PM   #10
JSeery
JSeery's Avatar
I know very little about post 48 engines! Was thinking in terms of pre 49, thanks Kube. Also, I use a modified oil filter system (with a sprin-on filter) and not the by-pass, anyone know the filter numbers for the post 48 by-pass filter?
Old 08-02-2016, 05:33 PM   #11
Kube
Kube's Avatar
I am with you there - most of what I know about '49 - '53 came to me pretty much by accident
I am fairly certain the '49 - '53 housing uses the same filter cartridge as the '40 - '48.
The body of the filter appears to be the same diameter and depth. It's the mounting bracket that is different.
Old 08-02-2016, 05:44 PM   #12
JSeery
JSeery's Avatar
Sorry, my misunderstanding! LOL
Old 08-02-2016, 01:03 PM   #13
Barlea
All Ford Canada 8RT truck engines had tall canisters for a filter maybe twice as long as the 8BA car engines.
Barlea is offline   Reply With Quote
Old 08-02-2016, 05:07 PM   #14
AAdams
AAdams's Avatar
For the tall canister used on truck engines the Wix 51503 is a direct replacement. It also comes with the correct gasket.
AAdams is offline   Reply With Quote
Old 08-02-2016, 03:57 PM   #15
Barlea
"I've got a "Varcon" oil filter in the 52 Merc. Bet nobody remembers them" Ralph, you need to change out that filter, Macleod's Hardware has been gone for what, 40 years? Used to buy flathead fuel pumps there for $2.65
Old 08-02-2016, 10:38 PM   #16
RalphG
RalphG's Avatar
You got it. I knew it would have to be another Canadian to recognize Macleods Varcon name. . It looked so clean and solid when I took the filter out that i took a chance and re-used the Varcon. Its a good strong looking filter with a metal case. Much like Fram.
I'm buying mostly Baldwin filters lately since they are the closest available.
Old 08-02-2016, 04:50 PM   #17
Ronnie
Ronnie's Avatar
Varcon I believe was a private branded Krallinator.
R
Old 08-02-2016, 05:58 PM   #18
mike42
mike42's Avatar
Just changed oil yesterday in my '40......NAPA # 1006
mike42 is offline   Reply With Quote
Old 08-02-2016, 09:35 PM   #19
Rand
Rand's Avatar
What RalphG said ☝
On both accounts
Rand is offline   Reply With Quote
Old 08-02-2016, 10:08 PM   #20
JSeery
JSeery's Avatar
If anyone is interested in filter comparison:
https://www.youtube.com/watch?v=YIcFgjEikUY
https://www.youtube.com/watch?v=8hvUNXv5Bg0
Like I posted earlier a lot of auto parts stores locally will have the oil filters cut apart so you can see what is inside. Frame is by far the poorest constructed filter I have ever seen. I guess they work to a degree, but if you are interested in quality they are not it.
In a by-pass filter application it is a little different, but Frame still uses poorer quality filter material and construction than just about anything out there.
