Old 02-11-2015, 09:14 PM   #1
buckroseau
Default Need help with this wheel stud?
Model T guys sent me your way. Hoping someone can help me with what to do about this wheel stud. Here is the thread I started in the Model T section, although I can summarize it real quick.
https://www.fordbarn.com/forum/showthread.php?t=161201
Not sure what this came off of, but I am in need of 10 wheel studs. Pics of the the drum and stud. Caliper says .62 dial. on the shoulder, .400 shoulder length. .750 of 1/2-20 thread.
I need 1.250 of thread.
Live chatted with Dorman today, they do not make a wheel stud with that small of dia. with a smooth shoulder. Wondering what my options are? Are people using knurled studs and if yes, what dia.?
Hoping you guys can help me out and steer me in the right direction.
Thanks, Matt
buckroseau is offline   Reply With Quote
Old 02-11-2015, 09:36 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Need help with this wheel stud?
Your photo of your set up pressing out the stud looks wrong to me.
It looks like you are only supporting the outer edges of your brake drum.
You must have a support around the immediate surrounding area of the stud head.
Maybe you do and it's just not clear in the photo to me.
If it's not supported correctly you will bent the hub at the very least if not crack/break it.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-11-2015, 09:42 PM   #3
buckroseau
Photo is clear, I will support the hub closer to the stud on the remaining 9. I only pulled 1 so far, it actually didn't take a ton of pressure to get it out, I was a little surprised. The others might be tougher to get out?
Any ideas on the actual stud on what to do?
Old 02-11-2015, 09:48 PM   #4
Fullraceflathead
A large deep well socket will work. I've done that in the past on my press.
If you can't find the studs you need in the Model A Vendors web sites call Bert's.
I'm sure they would have some Originals.
-Henry Ford
1941 Willy's Pickup
Old 02-11-2015, 09:50 PM   #5
buckroseau
I need them a 1/2" longer than stock. I'm assuming the vendors would have the same thing I currently have?
Old 02-11-2015, 09:56 PM   #6
Fullraceflathead
There is a Company in California called ARP. They make very strong studs, many styles used in Racing. They may have one "off the shelf" that will be what you need.
I know they can make you anything custom for a price. I use there Studs, Parallel Ground Washers and 12 Point Nuts in all of my Racing Engine Builds. They are the Best in the Business as far as I am concerned.
-Henry Ford
1941 Willy's Pickup
Old 02-11-2015, 09:59 PM   #7
buckroseau
I probably don't need studs this strong, but at least I have an option.
Thanks.
Old 02-11-2015, 10:01 PM   #8
Fullraceflathead
I wonder if the wheel Studs on the AA Trucks rear Duals are longer.
If so that might be what you need.
-Henry Ford
1941 Willy's Pickup
Old 02-11-2015, 10:04 PM   #9
buckroseau
You will have to forgive my stupidity....what is an AA truck?
Old 02-11-2015, 10:08 PM   #10
Fullraceflathead
AA is the 1 1/2 Ton version of the standard Model A.
The Heavy Duty Trucks, some had Dual Rear Tires.
They may have longer length Studs. I don't know but it would be something to look into if you call Bert's or a Vendor that carries AA Truck parts.
-Henry Ford
1941 Willy's Pickup
Old 02-11-2015, 10:13 PM   #11
Fullraceflathead
I think Steve could help you if the AA came with longer Studs.
I don't know him personally but Many Members on here Praise him very highly.
Steve Becker
Berts Model A Center
800-321-1931
303-293-3673
720-377-0063
303-484-7630 fax
[email protected]
www.modelastore.com
In our 35th year!!!!!!
Tues- Fri 9-4
Sat 8-12
MOUNTAIN TIME
-Henry Ford
1941 Willy's Pickup
Old 02-11-2015, 10:26 PM   #12
buckroseau
I will give him a call tomorrow. I was also thinking of stopping by little dearborn in Minneapolis. I Probably will be in that area tomorrow.
Steve Becker
800-321-1931
303-293-3673
720-377-0063
303-484-7630 fax
[email protected]
www.modelastore.com
Tues- Fri 9-4
Sat 8-12
MOUNTAIN TIME
Old 02-11-2015, 10:59 PM   #13
Joe K
Joe K's Avatar
And the AA truck had um, larger studs/wheelnuts. And they were arranged to be right hand/left hand for the appropriate sides of the vehicle. (Henry apparently feared the action of motion would "undo" the wheel nuts of the heavily loaded truck.)
Also for the rears a special setup with a nut within a nut to captivate the double-back to back wheels.
Joe K
Shudda kept the horse.
Old 02-11-2015, 11:17 PM   #14
buckroseau
Originally Posted by forever4 View Post
I am not sure why people are talking about trucks. Your drum is a 1932 front drum, and it uses completely different size studs than a Model A drum. Replacement studs are readily available from the V8 dealers.
Here is a link to a chart which will help you ID what you have or need.
Model A Ford Garage ~ Wheel Stud Chart
www.fordgarage.com/pages/wheelstuds.htm
Looks like I have part # B 1107. Dimension B (which is more or less what I am looking for) is 1.19".
Looks like rear wheel hub, part # 48 1118. Same type and has the longest dimension "B". 1.56"
This stud would only be .370" longer. I really would prefer .500" longer, but I probably could make this work.
Would Bert's have this?
Old 02-11-2015, 11:25 PM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
Little Dearborn sells early V8 parts, so give them a try tomorrow.
Old 02-13-2015, 01:20 AM   #16
KR500
KR500's Avatar
What is the need for a longer threaded profile, custom wheels?
KR500 is offline   Reply With Quote
