#21 | |
![]() Quote:
#22 |
![]() Flicking the points with a screwdriver may give you a false indication, as you may be covering up a bad or dirty set of points. Just unclip the brass leads at the dizzy cap and move them about 1/8th inch away from terminal on cap. Wind motor over, you should see a fat spark jumping across each gap. This will prove spark as far as the plugs without dismantling anything. |
#23 |
#24 | |
![]() Quote:
When the points are closed and the key is on, you have about 4 amps going through the coil and that will heat it up. If it still heats up with the points open or the key off, then you have a problem, such as the ignition switch terminal touching the gas tank. |
#25 |
the condenser screw should not spin so take toms advice and change it and use the fiber washer under the screw head...
so you say no spark to #1 ok that should not be but with having spark to 2,3,4 the engine should still run but with a miss.... did you try bringing it to TDC with the timing pin and make sure your rotor is pointing to #1? maybe the dist cam slipped position or there is a timing gear issue and it jumped. maybe the spark is crossfiring in the dist body some food for thought Last edited by Mitch//pa; 01-19-2015 at 11:05 PM. |
#26 | |
The screwdriver makes the contact . not the points. The actual correct way is the have the points closed and flick them open with a non conductive object. |
#27 | |
![]() Quote:
Yes, I can see that. I use a screwdriver but I watch how I use it. Works fine. |
#28 |
Check out the gap between the rotor and distributor body. If they are all the same swap out the distributor body.
Even with 1 cylinder not firing your engine should still run without quitting. The Gordon compressor runs with only 2 and there is a video that has a cut away engine running on one.
#29 |
I'm too lazy to back to the first thread about this so let me ask how do you know you are getting fuel?
Get a can of starter fluid and spray it into the carb. As it dies spray it again and see if you can keep it running with the spray can.
#30 |
One of the most difficult tasks always appears to be to try to help by "guessing" at an "unseen" very "simple" mechanical/fuel/electrical Model A problem from miles away.
Not trying to be funny; but just in case you are getting frustrated trying so many different "things", I would bet (2) fully loaded boxcars full of Model A "Whitewall" tires that a real good senior, grey haired local lawn mower mechanic could locate the problem & advise you of your problem in a jiffy. Not everybody has a good Model A mechanic close by; but real good "senior" lawn mower mechanics are everywhere. Realize this is not a response heard of often, but just hopes this can help to get you back on the highway with smiles ........ plus learn a little about the basics of non-computerized engine diagnostics. |
#31 | |
![]() Quote:
By stopping the engine with the points open, then shorting with a screwdriver I am showing the points need to be cleaned. This is for a no spark or poor spark condition, which is why the check is taking place most times. |
#32 |
Thank you all for all the suggestions. Just to recap.
The battery seems to be fine. The wiring seems to be correct. The coil sends a spark to the distributor (will double check for the strength of the spark and color). However when the ignition is on and the point are close the negative side of the coil is hot. (should be the positive side) Not sure why. The rotor turn and the gap to the contact is 0.25. However it wobble. It should rest on the cam right, but it seems that it is not resting flat. The cam screw slot has some burs maybe it does not allow the rotor to seat flat. The point gap have been sanded lightly and adjusted to 0.18. The distributor contact have been sanded lightly and have been check for continuity and they all checked out. Found a crack on the body near the external contact that goes to cylinder #4. The inside of the distributor is a little rough and hold the body (metal part exposed once I removed both upper and lower plate) is a little rusty. Can I just sand it? The condenser copper end spins (where the screws attach to it through the bottom plate) So I am ordering a bunch of parts to replace the coil, the distributor cap, body, both plate, the points and the condenser. While I am waiting for the parts. I have one more questions. What would be the symptom if the distributor condenser is not working properly? And still trying to figure out the coil issue. |
#33 | |
![]() Quote:
coil should be hot all the time as the black wire comes from the battery. Bob |
#34 |
if the condensor is failing you will have erratic spark or no spark. gotta have a good condenser. points ignition system is an LC circuit and all components must be in tip-top shape
'31 180A |
#35 | |
![]() Quote:
When the condenser is bad the engine will miss out, buck and backfire. In other words as has already been said, weak or poor or no spark. Two tests can be made on the condenser: Using a piece of wire touching the center or output of the condenser, charge up the condenser by touching the condenser's case to the positive side of the battery and the piece of wire to the negative battery terminal. Allow the condenser to charge for a few seconds, then quickly disconnect and lightly touch the wire to the condenser case. If you observe a spark as the wire gets right near the case, you may assume that the condenser is OK. You can also check a condenser with a condenser tester to measure capacity. Capacitance should be 0.3 microfarads. Also, using an ohmmeter measure the resistance between the wire or center and the case which should not be less than say 5 million ohms Last edited by edmondclinton; 01-20-2015 at 04:53 PM. |
#36 |
The condenser by Ford spec for the documentation I have should be .20-.25 Microfarads,
In testing a condenser you test for Capacitance, leakage, and resistance. I use an early Ford heyer test set which test for all 3 of these. I would NOT recommend the test stated in a post above to determine a condenser good or not. As Tom & Mitch said If the terminal is turning it is bad, I would recommend the "Short Proof" condenser and it will probably be the last one you will buy. If you have or know how to use a digital voltmeter I would check the voltage at your coil ( iginition switch off) terminals , should both be 6V+, terminal box studs ( should both be same voltage). If the voltage is lower on one than the other you have a bad connection inside the terminal box or back of the ammeter. If that is good turn on the ignition and with the points open check the voltage at the points, it should be about the same. If significantly lower you have a bad connection somewhere in the ignition cable or distributor plates. I gave a seminar last year at the MARC Membership meet on the "voltmeter is the best tool in your toolbox" . When you're having a no start problem it truly is. If you don If you don't have one go buy ( or tell your wife you have to have an early birthday present) a decent inexpensive one and start checking voltage to learn and get acquanted. You will always be glad you have it as a tool. Best of luck... keep the forum posted. Larry Shepard Last edited by larrys40; 01-20-2015 at 06:01 PM. |
#37 |
I'm with Larry. In the end, tho, the only real test of a condenser is, does it work in the circuit it is supposed to be in.
they are dirt cheap. always have a spare
'31 180A |
#38 | |
![]() Quote:
Sorry, I disagree. Ford's original spec was .3 microfarads. Also I said that when charging up a condenser and discharging on its case, one may "assume" that the condenser is OK. I didn't say it was guaranteed. The above method is something that almost any Model Aer can do and requires no test equipment. Using my equipment I measure condenser capacity and then insulation resistance measured between the condenser center and the case. The following link shows an original letter from Ford Motor Co. discussing the rating of the Model A condenser. www.fordgarage.com/pages/condensercapacitance.htm |
#39 |
By the way your condenser probably has to long of a screw and it is bottom out. That is why you can turn it. Check that before you have the same thing happen to your new one.
#40 |
Being an electrical engineer of way too many decades experience, I can safely say that the condenser will pass all sorts of tests with meters and such. It will fail actual use tests because the high voltage it is asked to suppress.
Without a tremendously sophisticated rig to observe its dielectric failure - just substitute a good one as mentioned above. And for those of you thinking the coil only has 6V on the primary, when the points open the primary of the coil rises in voltage till something gives - as evidenced by the arc across the points. The purpose of the condenser (capacitor) is to ensure complete magnetic field collapse. If this does not occur, the coil will magnetically saturate and not be able to build additional magnetic field when current is applied - thus no sparky. Rate of collapse is controlled by inductance of coil primary and capacitance of condenser - with a ton of Kentucky windage allowable in the actual cap value. By performing this function, condenser also protects points from excessive pitting - condenser takes the bulk of the current that would otherwise entirely arc across points. All right - sorry if I am preaching - lost my sister Friday night and guess I need a preacher! |
