Old 01-06-2015, 11:00 AM   #1
fredski
fredski's Avatar
Default radiator shell lacing please advise
I ordered a-16739-b lacing from snyders and did not receive the rivets
or maybe I throw them out with the plastic bag??
can I use regular rivets I have a rivet gadget and rivets. seems to require
25 rivets is that necessary to put them all in ?
what do you thing if I use goop [glue] and no rivets.
will buff and polish shell while waiting for your input.
fredski
fredski is offline   Reply With Quote
Old 01-06-2015, 11:57 AM   #2
George Miller
George Miller's Avatar
Default Re: radiator shell lacing please advise
They used a split rivets on the radiator shell. The cowl used hooks and I think three screws. I would try and find some split rivets. I think the venders sell them. This is what the 30-31 have.
George Miller is offline   Reply With Quote
Old 01-06-2015, 12:22 PM   #3
Big John
go to the hardware store and get split rivets..... do not bother with glue....John
Big John is offline   Reply With Quote
Old 01-06-2015, 02:01 PM   #4
wrndln
I agree with the posters above - use split rivets. There is a model T split rivet tool that I bought that correctly set the rivets. It worked very well.
Rusty Nelson
Old 01-06-2015, 04:15 PM   #5
hardtimes
hardtimes's Avatar
Hey Fred,
If working with avatar coupe, i.e.- '30/'31 the radiator shell 'lacing' is held on with four flathead screws, in addition to the split rivits.
Glue is a joke right, I get it
Old 01-06-2015, 04:28 PM   #6
Mitch//pa
when you order the split rivets from snyders get the split rivet tool also.. its cheap,, sets the rivets properly,,, works great.
Old 01-06-2015, 04:44 PM   #7
mshmodela
mshmodela's Avatar
Ditto on Mitch advice on the tool. I got one, it's a must.. Also, the original rivets were tough as a coffin nail.. I grabbed some cheap Large needle nose plies at Harbor Fright made the job easy..
http://www.harborfreight.com/11-inch...aws-39537.html
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 01-06-2015, 05:53 PM   #8
fredski
fredski's Avatar
Originally Posted by hardtimes View Post
Hey Fred,
my avatar is my 1930 town sedan with the doors off as at that time
I was installing head liner and new roof top.
glue was not a joke , but just an option I was considering.
I will get proper rivets as most suggest.
thankyou
Old 01-06-2015, 07:43 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
This is probably common knowledge, but I always use an awl to poke the holes for the rivets. I do the same for the 3 cowl screws and 4 clip rivets.
Old 01-09-2015, 01:12 AM   #10
ian Simpson
Originally Posted by Don Turley View Post
Original Model A radiator shell lacing was not held on with any type of screws; only with rivets. Please explain the location of these "four flathead screws".
On my 1928 Tudor, the lacing on the cowl is held on by two lengths of wire held by four flat head screws. The radiator shell lacing is held by split rivets.
Ian
ian Simpson is offline   Reply With Quote
Old 01-09-2015, 02:56 AM   #11
Mike V. Florida
Mike V. Florida's Avatar
I think he is talking about the shell to radiator screws that go under the lacing.
Old 01-09-2015, 04:39 AM   #12
C26Pinelake
Very sound advice as usual and as above please don't use glue.
Wayne
C26Pinelake is offline   Reply With Quote
Old 01-10-2015, 12:51 AM   #13
Mike V. Florida
But that is not what "hardtimes" said. And, even those are not "flathead" screws, which are intended to go into a tapered hole.
"Ford Model A Hardware" book, published by MARC & MAFCA shows those as "Special Flat Head Slotted Bolt, part number A20401, No.12-24 USF x 1/2" long". The closest thing that is being manufactured today is a "pan-head screw". The surface that goes against the metal is flat, not tapered.
These special bolts that attach the radiator shell to the radiator do not go through the lacing. The lacing goes over the heads of the bolts.
He doesn't have the restoration manual or the hardware book. To the average guy they are flat head screws and you have to admit they do look like the screw should go through the lacing. I offered to buy from him the Restoration guidelines and judging manual if he felt it was not worth the money, but have not heard back.
