The Ford Barn
-   -   Air Maze Air Filter on Zenith Carb Question (https://www.fordbarn.com/forum/showthread.php?t=271973)
Conaway2 10-31-2019 10:38 PM
’ve used the Air Maze filter for almost 30 years - recently replaced the ‘screen’ filter element for a real paper air filter. The rebuilt engine was installed in March, carb rebuilt a couple of months ago - engine runs very well. I can turn the GAV off and the engine begins to stumble, so I believe at 1/4 turn of the GAV out, the engine is getting a pretty reasonable mix of gas/air.
However, I changed spark plugs a couple days ago - swapped some Motorcraft pugs from Bratton’s (since March) for a set of Champion 3Xs and noticed that the Motorcraft plugs had quite a bit of carbon on them, I wondered if the air filter was making the fuel mix too rich. I;ve read about this, and wonder if I need to do something to the Zenith carb to compensate for the air filter.
thoughts ??
​​​​​​​thanks - Jim
redmodelt 10-31-2019 10:45 PM
Re: Air Maze Air Filter on Zenith Carb Question
Get rid of the paper element and put the screen back on. The paper element is a fire hazard. If it worked for 30 years why change it?
al's28/33 10-31-2019 10:47 PM
I agree, if you run an air-maze the use the wire screen DO NOT USE PAPER
30 Closed Cab PU 11-01-2019 01:06 PM
Or use a High Boy adapter with a K and N filter. If you do not care about looks, or are a purist, is an option
160B 11-01-2019 01:20 PM
Below is a list of all the posts on air filters
https://www.fordbarn.com/forum/showthread.php?t=250309 250309
https://www.fordbarn.com/forum/showthread.php?t=239089
239089
https://www.fordbarn.com/forum/showthread.php?t=221751
221751
https://www.fordbarn.com/forum/showthread.php?t=221691
221691
https://www.fordbarn.com/forum/showthread.php?t=216058
216058
https://www.fordbarn.com/forum/showthread.php?t=211210
211210
https://www.fordbarn.com/forum/showthread.php?t=209923
209923
https://www.fordbarn.com/forum/showthread.php?t=205402
205402
https://www.fordbarn.com/forum/showthread.php?t=142838
142838
https://www.fordbarn.com/forum/showthread.php?t=142421
142421
https://www.fordbarn.com/forum/showthread.php?t=119231
119231
https://www.fordbarn.com/forum/showthread.php?t=119203
119203
https://www.fordbarn.com/forum/showthread.php?t=108962
108962
https://www.fordbarn.com/forum/showthread.php?t=95961
95961
https://www.fordbarn.com/forum/showthread.php?t=81888
81888
https://www.fordbarn.com/forum/showthread.php?t=77165
77165
eagle 11-01-2019 04:20 PM
I've used an AirMaze for years. Plugs look great. I use a fiber mesh filter over the top of the AirMaze and use oil on the screen. I use about 1/4 turn GAV except when highway cruising. Then its maybe 1/8 open or less.
Bob Bidonde 11-02-2019 08:08 AM
Anything you put at the inlet of the carburetor is going to reduce the inlet air flow, and reduce engine power.
WHN 11-02-2019 08:14 AM
I would take this advise ASAP.
Ours has been on for over 40 years. No problems.
1/4 turn is also really good sign. Enjoy.
Jimczeb 02-23-2024 09:46 AM
how do i install the maze filter on my model A. any pictures available? do i need a rubber gasket?
Y-Blockhead 02-23-2024 09:59 AM
Just tighten the screw. https://www.snydersantiqueauto.com/p...9483&cat=41659
