Old 03-07-2013, 10:20 PM   #1
Phil Noonon
Default Mallory distributor shaft bushing
Hello All
Have been trying to find a source for a mallory series 2301105 shaft bushing? Can anyone help me out?
Thanks!
Phil Noonon is offline   Reply With Quote
Old 03-08-2013, 08:58 AM   #2
Tinbasher
Tinbasher's Avatar
Default Re: Mallory distributor shaft bushing
It may be a part you'll have to have a machine shop make up for you. Not a big problem. Tinbasher
Tinbasher is offline   Reply With Quote
Old 03-08-2013, 10:21 AM   #3
1931 flamingo
1931 flamingo's Avatar
Try going to the EV8 board and do a search for "Bubba", he may be able to help you.
Paul in CT
Old 03-08-2013, 11:39 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
There is a bearing and seal store about 5 miles from me. Give them the ID, OD, and length and they might have it on hand. Cutter Sales 763-425-8696, Paul is the owner.
BTW, there are a few good hardware stores that still have trays of bushings.
Old 03-08-2013, 08:29 PM   #5
Phil Noonon
thanks gentlemen, some of you have a trove of information!
Old 03-09-2013, 12:40 PM   #6
just plain bill
just plain bill's Avatar
I use mostly off the shelf oilite bearings. Most of the shaft problems I have found were caused by lack of lubrication, In the recent past I have found most frozen shafts to be caused by not drilling the oil passage in the upper shaft bushing. I have found this both on Mallory's and model B distributors. On the Mallory's I remove the outer plug then after drilling the oil hole in the bushing I drill and tap for Allen set screw to plug. On the B's I grip the oiler in the vise and then carefully tap on the distributor body with a piece of lead to remove the oiler then after drilling the bushing I drive in a new oiler being careful to align oil hole in the oiler up. I have predrilled the bushings in the past but find the drilling after installation easier on old eyes
just plain bill is offline   Reply With Quote
Old 03-09-2013, 01:16 PM   #7
Tom Wesenberg
Here's a link to removing the oiler. Scroll down to #5 andwhile gripping the screwdriver handle give it a good clockwise twist and the oiler should pop out with no damage. If it's to tight to twist the screwdriver, then use the screwdriver in the same position as a lever, and lift a little to get the oiler moving.
https://www.fordbarn.com/forum/showth...tributor+oiler
