Old 02-24-2013, 10:04 AM   #1
JRHASZARD
JRHASZARD's Avatar
Default Removinf Rad Shell Emblem
I unfastened the steel inserts on a 31 radiator shell for bead blasting and painting. They are very pitted.How can I remove and reinstall the FORD emblem on the top insert so I can bead blast,fill the pits and paint it without damaging the emblem? It looks like it can be driven out but the insert is so rusty I don't want to use too much force. Thanks, John
JRHASZARD is offline   Reply With Quote
Old 02-24-2013, 10:17 AM   #2
Roadster62
Roadster62's Avatar
Default Re: Removinf Rad Shell Emblem
Here is one I have, looks like there was a dab of solder applied on top to hold it in place. Try some heat and press it out using a socket with the right diameter. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 02-24-2013, 10:28 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Spray some penetrant on the clasp. I made a special tool that only presses on the very outer edge of the clasp. I made 38 of these tools and sold them. Maybe someone in your area has one you can use. If not, then you can make one from a piece of pipe. Cut a taper on the end so the outer edge is what hits the clasp. I made mine from solid brass that was chrome plated.
Old 02-24-2013, 10:44 AM   #4
TudooR31
TudooR31's Avatar
I was wondering why the painted area gets rusty/pitted while the exposed unpainted edge is not. I assume the whole insert is made of stainless like the grill surround? Is it the paint that etches the stainless surface promoting eventual rust?
TudooR31 is offline   Reply With Quote
Old 02-24-2013, 03:40 PM   #5
Chris Haynes
Chris Haynes's Avatar
I used a block of 2x2 whittled round and a hammer to remove mine.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 02-24-2013, 05:09 PM   #6
wrndln
I can attest to Tom Wesenberg's very neat tool. The tool is ingenious. He removed emblems from two of my shells in about 2 minutes with no damage to the emblem or shell. It only touches the very outside edge of the emblem mounting.
Rusty Nelson
Old 02-24-2013, 06:08 PM   #7
Bruce,Upstate NY
I use a deep socket that fits at the outer edge od the disc and give it a rap with a hammer.
Bruce,Upstate NY is offline   Reply With Quote
Old 02-25-2013, 12:17 AM   #8
JRHASZARD
JRHASZARD's Avatar
TudooR31, the painted inserts are mild steel and succeptable to rusting. They are tabbed into the outer shell which is stainless (allegheny metal ),
I taped over the trim with Gorilla tape and bead blasted them. Worked fine. I will go back and try to remove the solder and turn a removal tool. Thanks for the help.
