Old 02-20-2013, 11:47 AM   #1
Duffy1
Default rear slinger repair kit
I have done a search but can find no info on who sells this repair kit . Appreciate it if someone could point me in the right direction .
Duffy1 is offline   Reply With Quote
Old 02-20-2013, 12:23 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: rear slinger repair kit
What is actually broken? The "slinger" is usually considered a portion of to crankshaft.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-20-2013, 06:40 PM   #3
Duffy1
The slinger has been ground off . Would like to restore as original.
Old 02-20-2013, 07:06 PM   #4
MikeK
MikeK's Avatar
It would be possible to build up the missing slinger and re-machine it, but it would be much easier to get another crank if you want the original setup. The crank may have had a Burtz seal, available from the catalog vendors.
MikeK is offline   Reply With Quote
Old 02-20-2013, 09:28 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
I think that Tom Wessenberg had the rear slinger replaced. I wouldn't have thought that it could be done. I'm not sure if the spelling or name is correct but I think the guys name was Rich Faluka, please forgive the spelling if wrong .
Old 02-20-2013, 10:25 PM   #6
James Rogers
James Rogers's Avatar
Completely off or just down to the level of the thrust? Rich Fallucia at Antique Engine Rebuilding can restore it and I have been privy to his method and believe I could also.
Old 02-20-2013, 10:27 PM   #7
Duffy1
Thanks for the responses . I saw an article some where describing a repair kit/procedure in which you solder the slinger onto the crankshaft.
Old 02-21-2013, 02:13 AM   #8
hardtimes
hardtimes's Avatar
Actually his name is...Richard Fallucca DBA Antique Engine Rebuilding. Duffy, you can google Richs phone # and talk with him regarding your request. However, as stated your crank may have been modified to use Terry Burtz seal...to prevent oil leaks. I use Burtz seals and they do not leak. Good luck.
hardtimes is offline   Reply With Quote
Old 02-21-2013, 11:10 AM   #9
Duffy1
Thanks for the response folks . Will try another modern seal .Will advise what type engine builder uses.
