#1 |
Installed new inserted engine from Antique Engine and Snyder HC head. Absolutely happy after about 400 miles except clutch will slip when i "get on it" at about 30 mph. I replaced clutch disc and "inspected" the pressure plate.
Am I overlooking something obvious or is it new pressure plate time? Was looking at the new one listed in Snyders. Will this handle all my new "raging power˝? Bob |
#2 |
Are you sure you have correct freeplay?
Maybe your new engine has too much horsepower! ![]() |
#3 |
Does the A clutch plate have an offset centre? I had a 64 Holden that ran fine until I went to take off uphill one day, the clutch slipped and wouldn't grab completely. I nursed it home, figuring the clutch was just worn out. When I got the plate out, the centre had almost been cut through. The centre is offset forward and rear, and it was installed the wrong way around, and I could still read the markings saying which side faces the flywheel. The previous person who installed the plate got it wrong.
#4 |
Free play is adjusted properly. Never had slipping issue with old engine and worn disc.
#5 |
