Old 02-12-2013, 08:50 AM   #1
JonC
Default 40 pickup radiator mounting
I was wondering if someone can tell me or show me how the radiator on a 40 pickup mounts. I know there are two bolts and springs at the bottom but what about the top. I ask beacuse I had a car radiator of uknown year (I thought a 40) modified to accept the lower metal hoses, and now I don't remember what the top mounting was like. Thanks.
JonC is offline   Reply With Quote
Old 02-12-2013, 09:51 AM   #2
my2nd40
my2nd40's Avatar
Default Re: 40 pickup radiator mounting
Two braces, one on each side of the radiator that attach to the inner fenders. http://www.bobdrake.com/ItemForm.aspx?Item=91A-8046
my2nd40 is offline   Reply With Quote
Old 02-12-2013, 10:43 AM   #3
19Fordy
19Fordy's Avatar
A SEARCH shows this info:
https://www.fordbarn.com/forum/showth...iator+mounting
19Fordy is online now   Reply With Quote
Old 02-12-2013, 12:22 PM   #4
JonC
Thank you for your help.
Old 02-12-2013, 05:03 PM   #5
oldrelics
Originally Posted by 19Fordy View Post
The rad rests on the spring? If I did that the crank hole would not line up with the crank......
The pickups I've found (whether its right or wrong) had the rad tabs sit on pads on the frame, the springs on top with the castle nuts on top.
oldrelics is offline   Reply With Quote
Old 02-12-2013, 05:41 PM   #6
Mart
Mart's Avatar
That's how it should be. The pads are quite thin. The springs are there to allow a little "give" on very twisty roads and severe jarring bumps.
Mart.
