Old 01-25-2013, 05:05 AM   #1
Step-down
Step-down's Avatar
Default Powermaster Vintage Torque starter motor *******************
The starter motor needs replacing on my 39' I've read a little about these repop stater motors from Powermaster.
Any feed back .....USA made don't know .....Thanks
Powermaster Vintage Torque starter motor Ford Flathead V8
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 01-25-2013, 07:25 AM   #2
don35
Default Re: Powermaster Vintage Torque starter motor *******************
Slightly different situation but, the same company made the product. I have a Powermaster starter on my Nissan pickup that has a Chev v-8 in it. Huge difference over the stock starter, spins much faster, even when hot. Well worth the cost to me.
don35 is offline   Reply With Quote
Old 01-25-2013, 09:51 AM   #3
37fatfender
37fatfender's Avatar
I own 4 of them 2 on flatheads, 1 SBC, 1 Ford Turbo Diesel. Really made a difference on the Turbo Diesel.
37fatfender is offline   Reply With Quote
Old 01-25-2013, 10:15 AM   #4
Brendan
Brendan's Avatar
why not the original starter? they work great!
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 01-25-2013, 10:26 AM   #5
Krylon32
I've used the Powermaster starter on my last 4 FHs and they have worked great.
Krylon32 is offline   Reply With Quote
Old 01-25-2013, 10:53 AM   #6
Seth Swoboda
Seth Swoboda's Avatar
What voltage are you running, 6 or 12? I am assuming it's 12 volt. I would save the money and just run an original ford starter. It will spin fast on 12v. I have never had any problems with that set up.
Seth Swoboda is offline   Reply With Quote
Old 01-25-2013, 02:26 PM   #7
Pete
It is a gear drive positive shift type starter so not only do you get a lot more torque for starting in cold weather, you NEVER have to worry about breaking a bendix spring or bolts.
They are smaller and lighter than a stock one also.
