Old 01-09-2013, 04:48 PM   #1
AL in NY
AL in NY's Avatar
Default Genuine Autolite Heater Door
I thought this might get better exposure as a separate thread:
Here are are few pictures of a genuine Autolite heater door. It fits into the back of the heater cover perfectly and has two doors. The outer door is manual operated and can be set at any angle. The inner damper door is spring loaded and is operated remotely using a choke style cable. I picked is up at Rhinebeck two years ago and will be installing it this spring to keep my "better half" warm on those cool morning rides.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-09-2013, 04:49 PM   #2
Chris Haynes
Chris Haynes's Avatar
Default Re: Genuine Autolite Heater Door
Thank you for posting that. Now I can see that the cover says Autolite on it. ;-)
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 01-09-2013, 06:00 PM   #3
Marco Tahtaras
Marco Tahtaras's Avatar
I can now see one reason why they aren't that common. That configuration would transfer vibrations and noise right to the firewall. It sure has a clean look however.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 01-09-2013, 08:02 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Marco,
I thought precisely rebuilt & assembled Model A's didn't VIBRATE!!~~~~~~~~~~~~~~~~~~~I figured out this symbol It's a vibration symbol~~~~~~~~~~~~~~~~~~~~~~~~ B B B Bill W. (Now I got the D D D Dog shakin')
"THE ASSISTANT GURU OF STUFF"
Old 01-09-2013, 11:18 PM   #5
Milton
Milton's Avatar
Certainly not to be used with Float-O-Motor mounts.
Milton is offline   Reply With Quote
Old 01-09-2013, 11:21 PM   #6
Marco Tahtaras
Bill will have to confer with the Dog on that one!
Old 01-09-2013, 11:31 PM   #7
bbrocksr
Are you sure there is not a flexible connection of some sort to isolate the vibrations from the firewall?
Bill
bbrocksr is offline   Reply With Quote
Old 01-09-2013, 11:41 PM   #8
Pickupman
Thanks for the pics!
Pickupman is offline   Reply With Quote
Old 01-10-2013, 01:03 AM   #9
Craig Lewis
Craig Lewis's Avatar
Bill
My coupe arrived with an Autolite heater, except I didn't get that nice door.
Here's a picture showing the proximity to firewall...looks like maybe 2 -3 inches, no room for a hose really...
Craig Lewis is offline   Reply With Quote
Old 01-10-2013, 06:09 AM   #10
ctlikon0712
ctlikon0712's Avatar
No, no, you guys have it all wrong. That design is brilliant! It keeps the rear of the manifold from drooping from the heat and muffler weight!
In all seriousness Al, that is a great find and I kept every pic you posted as reference.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
