Old 01-07-2013, 01:33 PM   #1
Paul in Colorado
Paul in Colorado's Avatar
Default Generator Cleaning Question
What can I use to clean the body of a cylindrical generator - inside and out - without damaging the field coils?
Paul in Colorado is offline   Reply With Quote
Old 01-07-2013, 02:06 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Generator Cleaning Question
I use compressed air and a syphon sprayer with gas. I prefer to use gas with NO ethanol.
I made some end plates to cap off the field coils while I sandblast the case.
Old 01-07-2013, 06:27 PM   #3
Paul in Colorado
I cannot get gas with no ethanol. Is there anything else which will not damage the field coils? How about brake cleaner or paint thinner?
Paul
Old 01-07-2013, 06:29 PM   #4
John Stone
John Stone's Avatar
How about naptha?
John Stone is offline   Reply With Quote
Old 01-07-2013, 06:30 PM   #5
jmeckel
jmeckel's Avatar
I use mineral spirts and blow out with compressed air.
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 01-07-2013, 10:58 PM   #6
Tom Wesenberg
Paul
I have used gas with 10% ethanol and blow dry it right away, and there has been no damage. It sure hurts the hands more than the good gas though.
Old 01-08-2013, 11:08 AM   #7
Jim Brierley
Paint thinner.
Jim Brierley is offline   Reply With Quote
Old 01-08-2013, 11:41 AM   #8
jimvette59
jimvette59's Avatar
I used Electro Clean. It's a commercial product I don't remember where I got it but try and Google it. Jim.T.
jimvette59 is offline   Reply With Quote
Old 01-08-2013, 04:14 PM   #9
Mikeinnj
Mikeinnj's Avatar
I believe that Tom is saying to clean the outside of the generator only.. Do not clean the coils with solvent.
Mikeinnj is offline   Reply With Quote
Old 01-08-2013, 08:38 PM   #10
Tom Wesenberg
I've also cleaned the coils with my syphon sprayer and gas. I don't soak them, but a quick cleaning with the compressed air and gas will clean the junk off without hurting the coils. I stay back from the wrappings a bit with the compressed air. Sometimes I use gas and a soft paintbrush.
Old 01-08-2013, 09:36 PM   #11
partridgekelley
NAPA sells an electromotive cleaner in a spray can. But the books say not to use anything that will desolve the coating on the field coils. I was wondering how kerosene would work = much easier on your hands too. I don't care to use the more powerful cleaners.
partridgekelley is offline   Reply With Quote
Old 01-08-2013, 09:46 PM   #12
jimvette59
jimvette59's Avatar
He mentioned the coils also. I use Lectro Clean it is made for electric motors.
Old 01-10-2013, 08:08 AM   #13
Tom Wesenberg
Here is a Canadian powerhouse I just finished yesterday. I used gas in my syphon sprayer to clean the armature and field coils. After I repaired the armature, and undercut and polished the commutator, I sprayed clear laquer on the armature. This helps hold the wires and insulator together.
If you look near the center bottom of the armature, you can see a small silver dot. That is where I had to solder a 2" piece of copper wire from one of the coils to the commutator segment. I don't know how that wire was broken off and missing, and it didn't show up as a problem on my growler, because it's an OPEN, not a short. This appears to be a rewind on the armature, and a few pieces of the heavy insulator are missing where the wire leaves the core. I used clear epoxy to lock the wires in place so they don't rub on the sharp edge of the core. It was good to be able to save this armature because no one rewinds them anymore, and they and the brush holders are hard to find good spares.
I also replaced someone's stiff red plastic output wire with a soft very flexible black wire with 160 strands.
Canadian powerhouse generators are easy to spot by the thick outside of the case. Notice the case gets very thick after the rear cover area, where the common powerhouse has a straight side.
Old 01-10-2013, 11:13 AM   #14
Paul in Colorado
Thanks for all the information and suggestions. I used paint thinner (mineral spirits) with an old toothbrush to clean the interior and coils. The armature is in good shape with minimal cleaning. I'm sure there is still some debris where the toothbrush was not able to reach, but I am not going to worry about it. The outside of the case is not rusted, so I am just cleaning and repainting it.
Paul
