Old 12-31-2012, 08:41 AM   #1
mike42
mike42's Avatar
Default Winter Storage
I've got a '40 sedan with Coker Tires. Someone told me when storing for Winter to put carpeting under each wheel. Any comments or recommendations on this?
Thx.....Mike
mike42 is offline   Reply With Quote
Old 12-31-2012, 09:14 AM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Winter Storage
I've never heard of such in all my born days, and I am 81.
Old 12-31-2012, 09:27 AM   #3
Mike51Merc
Mike51Merc's Avatar
Wink Re: Winter Storage
Shag works well, but it's getting harder to find.
Sorry, couldn't help myself. I now have to resolve to not be a wise-ass in the new year.
Mike51Merc is offline   Reply With Quote
Old 12-31-2012, 09:41 AM   #4
done4
done4's Avatar
Send a message via Yahoo to done4
Originally Posted by mike51merc View Post
shag works well, but it's getting harder to find.
too funny!
Still smokin tires and cigars
done4 is offline   Reply With Quote
Old 12-31-2012, 09:50 AM   #5
53F100Jeffie
53F100Jeffie's Avatar
I have my trucks and a Model fordor sedan in our Fire Co.'s Pole barn. I have two of the vehicles on carpet. I have them on carpet as a barrier to moisture, not to protect the tires. I have had a set of Firestone's on two of my truck for ten years, on and off carpet, they are like new still. I have heard of letting a little air out of the tires, but I don't think that would be good for the side wallls.
Whatever you decide, good luck with it.
Jeff
1929 Model A Fordor
1949 Ford F1 Panel Truck
1953 Ford F100 Pickup
2006 Ford F150 XLT Scab 4x4
"I'd rather drive a truck" - Rick Nelson
53F100Jeffie is offline   Reply With Quote
Old 12-31-2012, 09:58 AM   #6
G.M.
I don't think carpet will do anything except protect the floor. Put it up on jack stands to protect the side walls. The main problem is the ethenol fuel. It attracts water and causes problems with the sending unit and corrousion to the tank. There is an additive you should put in, I don't know the name. Not Stabil but something like Stratus?? G.M.
www.fordcollector.com
Old 12-31-2012, 10:01 AM   #7
G.M.
53F Soaking in water is used to revive rubber. G.M.
Old 12-31-2012, 10:05 AM   #8
mike42
mike42's Avatar
Hey Mike51....you're a funny guy !! I just happen to have some '60's Avocado Green Shag that would be perfect. I'll have to take it up off the floor though !!
GM....we have recreational fuel in Michigan and I use it all the time. You pay 20¢ more per gallon but it works great.
"Shag" ......that was a good suggestion !! Mike 51 I can't thank you enough !!
Mike42
Old 12-31-2012, 10:19 AM   #9
Old Henry
Old Henry's Avatar
Here's how much I don't think it matters. Before restoring "Old Henry" he sat outside with flat tires sunk into the ground for 31 years. When we were ready to move him we just pumped up the tires and drug him away. The tires were still round, the sidewalls were OK and we drove the car on those tires for the year we were restoring it without a problem. Only one of the 4 old tires eventually went flat and had to have a leak fixed but the others were fine from the day we pumped them up. No carpet.
Old 12-31-2012, 12:03 PM   #10
Scott H in Wheaton
Scott H in Wheaton's Avatar
Old Henry..
Yeah you got 31 years out of those tires but I'll bet they won't last 31 more! The carpet trick might have saved you the cost of a tire!
Scott H in Wheaton is offline   Reply With Quote
Old 12-31-2012, 01:40 PM   #11
Vic Piano
Vic Piano's Avatar
I think the carpet might be good to wipe you shoes, before you get into the car, but that's about it.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 12-31-2012, 01:51 PM   #12
sonny
sonny's Avatar
Carpet holds moisture. If I had to store mine in an unheated garage I would lay down plastic as a moisture barrier.
sonny is offline   Reply With Quote
Old 12-31-2012, 06:22 PM   #13
millersgarage
millersgarage's Avatar
Carpet is for the mice to eat, so they get full before getting into your interior....
I always put mine up on jack stands to take the weight off the tires.
millersgarage is offline   Reply With Quote
Old 12-31-2012, 06:31 PM   #14
raceron1120
raceron1120's Avatar
Wow this is funnier'n Jack Benny making fun of Don Wilson.
Carpet - shag or otherwise - under tires? I've never heard that one either.
But to be safe, I guess I'd better bring the car into the living room, and move the beanbags & love beads to the garage to make room for Vicky. . .
raceron1120 is offline   Reply With Quote
