Old 12-28-2012, 11:47 PM   #1
josh414
Default 35 wheel adapters
I started a 32 sedan project in one direction and am now heading into another with it. I have 4 wheel disc brakes with 5 on 4.5" pattern but now want to run a set of 35 wires that I have. I am wondering if anyone knows of an adapter for this without spacing the wheels way out.
Thanks in advance- Josh
josh414 is offline   Reply With Quote
Old 12-29-2012, 01:11 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 35 wheel adapters
Most adapters are 1" thick.Try to find 1 1/4" thick ones because of the recess of the mounting flange of the stock 35 wires.They do appear on EBAY all the time.
deuce lover is offline   Reply With Quote
Old 12-29-2012, 01:30 AM   #3
T&A Flathead
Rally America makes and sells them. I think they are a hamb alliance vendor. Theirs has the support ring/lip built into it so entire load isn't on the lug holes.
T&A Flathead is offline   Reply With Quote
Old 12-29-2012, 09:36 AM   #4
Uncle Bob
Uncle Bob's Avatar
As noted, the adapters add an inch or so to the track width on each side. You might consider another alternative, and Rally America would be one source, have a 4 1/2" center welded in the '35 wheels to replace the stock one. No offset issues then.
Depending on the style of disc/hub you've got you could also have those redrilled to the 5 1/2" pattern.
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
Old 12-29-2012, 12:23 PM   #5
36tbird
Does anyone know? Can you mount '35 wire wheels on the disc kits that are 5 on 5 1/2? I'm asking this related question because of an idea I have for a future project car.
36tbird is offline   Reply With Quote
Old 12-29-2012, 03:19 PM   #6
deuce lover
36tbird, No. All early Ford wire wheels mounting surfaces are recessed in on the hub flange so adapters or spacers with support lip as T&A noted are needed.Wheel Vintiques makes a wire wheel that will work for you.
Old 12-29-2012, 11:22 PM   #7
josh414
Thanks for all the help.
Old 12-30-2012, 03:43 AM   #8
Mart
Mart's Avatar
I would guess that most disk brake kits that have 5-1/2" bolt pattern will work with 40's style steels, but PROBABLY not with wires. Quite apart from the raised support needed near the center of the wheel, the wires have a big piece at the outer edge of the center that goes back a long way. This will foul most disk brake calipers.
Anything can be solved by moving the wheel out with an adaptor, but whether the added offset would be desirable or not is another matter.
I have seen a model A running 35 type wires with disks, but I do not know if it was a commercial kit or home made.
Mart.
