Old 12-16-2012, 01:28 PM   #1
Working Class Zero
Working Class Zero's Avatar
Default 1930/31 Frame Oddity
Put my model a truck cab on frame. Cab was from a 1930/31 AA. All the mounting holes on the frame lined up perfectly but one. The bracket on frame under the cowl only hits one hole. The bracket looks to need to be moved forward a couple inches and will fit? The bracket looks to be factory riveted and fit fine on AA chassis. Was there variation in 30/31 frames? I thought they were all the same, coupe, sedan, roadster, truck..... I can easily relocate the bracket, but it's a matter of curiosity. I'm baffled..... Any help here? Thanks!!!
Working Class Zero is offline   Reply With Quote
