Old 12-05-2012, 07:04 PM   #1
john hamilton
john hamilton's Avatar
Default capri engine in model a
That Pinto thread was too long. A Capri engine was just like the Pinto but with more hp. I put the engine and 4-speed in one and it fit perfectly. The shifter was in just the right place. The Pinto shifter was not in a good place.
It just took some simple flat pieces bolted in for front mounts and a tube across the frame for the tranny mount. Could have easily been reversed.
john hamilton is offline   Reply With Quote
Old 12-05-2012, 08:24 PM   #2
kenparker
kenparker's Avatar
Default Re: capri engine in model a
Is the Capri engine a 2.0 liter or a 2.3 liter? I am installing a 2.3 in a chassi now.
kenparker is offline   Reply With Quote
Old 12-05-2012, 08:50 PM   #3
john hamilton
Capris were 2300 cc. I had a Model A exhaust system hooked up and it sounded like an A. To the uninitiated it looked like some type of early A conversion. Who was I to deny it?
I only did it because the car was assembled junk and the A engine wore out. The parts were all from different years and the fenders were plastic. Guess I didn't mention I put in a Jaguar XK-E running gear.
Old 12-05-2012, 09:41 PM   #4
Jordan
Jordan's Avatar
Before the police show up, I'd like to see more pictures. I have no plans of running anything besides an A engine, but I would like to see how it's done.
Cowtown A's
Jordan is offline   Reply With Quote
Old 12-05-2012, 11:34 PM   #5
1oldtimer
1oldtimer's Avatar
I would also like pics of the trans and install.
1oldtimer is offline   Reply With Quote
Old 12-05-2012, 11:50 PM   #6
5window
5window's Avatar
Guess I'd leave it here-it sure wouldn't fly over on the HAMB!
5window is offline   Reply With Quote
Old 12-06-2012, 02:00 AM   #7
fordcragar
fordcragar's Avatar
What are you using for a transmission and rearend?
fordcragar is offline   Reply With Quote
Old 12-06-2012, 09:30 AM   #8
kenparker
kenparker's Avatar
Boy! Is this ever gonna stir up the Model A police. Engine and trans are mounted in the frame. Had to custom build some engine mounts and had to do some other custom engineering to make things work. The tranny is a C-3 fromm a 70's Fairmount and the Rear end is not decided yet.
Old 12-06-2012, 09:47 AM   #9
PetesPonies
PetesPonies's Avatar
John, the early Capris also got the 2000 engine.
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 12-06-2012, 09:49 AM   #10
PetesPonies
Ken, can I PM you for some specifics of your install?
Pete's Ponies
Old 12-06-2012, 11:26 AM   #11
kenparker
kenparker's Avatar
Petesponies, sure PM me anytime.
Old 12-06-2012, 11:52 AM   #12
newshirt
newshirt's Avatar
This is much more interesting than the "restoration" theme of this forum. Let's have two hamb's!
Ray White
newshirt is offline   Reply With Quote
Old 12-06-2012, 12:32 PM   #13
Charlie Stephens
Ken/Pete,
I am sure a lot of people are interested in this topic. Instead of giving the details off line I would like to suggest a thread on HAMB with a reference here to the thread.
Charlie Stephens
Old 12-06-2012, 01:17 PM   #14
CarlG
CarlG's Avatar
There's a 29 frame with a pinto engine / c4 tranny on the swap meet page right now.
https://www.fordbarn.com/forum/showthread.php?t=91020
Old 12-06-2012, 04:20 PM   #15
1oldtimer
1oldtimer's Avatar
It's really a 2.3, but still would work.
Old 12-06-2012, 04:22 PM   #16
CarlG
CarlG's Avatar
Seller's description, not mine.
Old 12-07-2012, 04:21 PM   #17
1oldtimer
1oldtimer's Avatar
Sorry Carl, I was correcting the ad not you.
Mine came with an early Pinto 2.0 in it. Too stock for the HAMB and not stock enough for the Barn..........
Old 12-07-2012, 09:27 PM   #18
PetesPonies
2.3 can be considered a Pinto engine as well. More 2.3s made it into Pintos than 2000s did.
Pete's Ponies
Old 12-07-2012, 10:52 PM   #19
James Rogers
James Rogers's Avatar
The 2.3 LL Mazda was the most prolific Ford engine used in any car or truck. This engine was used in the same basic design from 1974 till 1997 and in HP ratings from 90 to 205 the difference being carburation and cam design. Other improvements were to the ignition system and compression. If you want a hoss to use in a hot rod A, get a turbo charged intercooled engine from an 84-86 Mustang SVO rated at 205 HP with a 5 speed. Lots of horses from a little 140 CI four cylinder.
I am putting the head on my Ranger tomorrow because of a burnt valve. I got it for 500 and a replacement head and gaskets cost 400. Pretty good truck for 900$. This is the 8 valve 8 plug model introduced in 1988 and ended in 1997. Easy motor to work on and keep in tune. I checked the cylinder bores and can still see some cross hatch with 206000 miles on the odo.
Old 12-07-2012, 10:55 PM   #20
Glenn C.
Glenn C.'s Avatar
When your on a tour, who wants to look under the hood anyway? It's your A, build it, and drive it to enjoy.
Glenn C. is offline   Reply With Quote
