Old 10-12-2012, 09:38 AM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Understanding the "load-a'matic" distributor
UNDERSTANDING THE LOAD-A-MATIC FULL VACUUM DISTRIBUTORS
JIM LINDER “BUBBAS Hot Rod Shop” www.bubbashotrodshop.com
Ford made the “load-a’matic (full vacuum) distributor from 1949 until 1957 on most of their engines . This distributor is very much mis-understood by many owners etc.
The load a matic works by adding spark advance thru a vacuum chamber using vacuum differential at the carburetor.This vacuum signal from the carb is very low with advance typically starting at ½ inch of vacuum and being full advance at 2 inchs of vacuum.
The slightest change in the engine vacuum makes this unit become a problem and not supply the correct signal. A carb change is the most common problem making this unit not work. Twin carbs, a camshaft change also makes the unit become inoperative. I have talked to many owners with the vacuum line disconnected with complaints of engine overheating ( retarded ignition timing) and a poor running engine.
The “fix” for this problem is to use a later distributor that has full centrifugal advance that needs no vacuum signal and is operated by rpm alone . ( may also use vacuum advance as well on some units)
For the 1949-53 Flatheads we offer a remachined Chevrolet unit with a curved mechanical advace suitable for the flathead engine design. We have built and shipped over 700 of these units to very happy customers over the last years..
$180 plus $18 shipping
The 223 six is another story and requires some more thought as the oil pump drive is different at the base of the distributor . Ford offers at least three different drives with a spade, 5/16 hex and a 3/8 hex drive for the distributor oil pump drive.
For these we use a “ butt change” we take the lower drive end of your existing unit and mate it to a later ( full mechanical advance) unit, use another distributor ( like a Chevrolet six) or a older Mallory etc.
$250 plus $18 shipping
Picture on left is early “full vacuum” load a matic design, note exposed springs and adjustable pins. Picture on the right is the later centrifugal advance with weights and springs under the point plate.
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
