Old 10-09-2012, 06:24 PM   #1
all american boy
all american boy's Avatar
Default Ford Y Block Duraspark Ignition Conversion
y blockers
i'm doing it the simplest way.
converting my O ring y block distributor
by putting Duraspark parts in my housing.
if somebody wants to put a Duraspark distributor
in a Y block that's the other way.
have a nice day!
'Has racing made you a millionare?'
'Yes it has.Before I was a multi-millionaire.'-Quote
all american boy is offline   Reply With Quote
Old 10-09-2012, 06:31 PM   #2
all american boy
Default Re: Ford Y Block Duraspark Ignition Conversion
y blockers
here's a link that covers the conversion pretty good.
http://home.earthlink.net/~rcfaulcon...aspark/eec.htm
there's tons of info on it in all the Ford type forums.
here are pic's of cap & cap adapter.
have a nice day!
File Type: jpg Duraspark Eichlin Distributor Cap Adapter.jpg (14.3 KB, 6 views)
Old 10-11-2012, 09:07 PM   #3
Frankenstein57
Frankenstein57's Avatar
That's a good link, looks like a bit more work than the pertronix. Have to look at my junk, I might have this stuff laying around. Mark
Frankenstein57 is offline   Reply With Quote
Old 10-12-2012, 01:01 AM   #4
all american boy
frankenstein/mark
the question mark is whether the Windsor distributor is
identical in all ways except the gear size.
one thing to check is the oil pump intermediate shaft
to see if it's 1/4" hex.
then next would be length of shaft.
basically if it's the same from o ring mounting point in block down to shaft.
ok, back to swapping Duraspark internals into a y block distributor case housing.
i think the breaker plate is the 'make or break' item.
they have to be interchangeable.
have a good one!
Old 10-12-2012, 01:23 AM   #5
all american boy
y blocker's
here's another link that confirms you can swap internals.
http://www.ford-trucks.com/forums/10...duraspark.html
i myself would use a new control box to avoid problems.
NAPA has one with a blue 'protector' on back for @$30.
i found Duraspark parts by adding phony vehicle.
1978 Ford F100 w/400 engine.
have a nice day!
File Type: jpg Durspark Ignition Control Module Front.jpg (23.8 KB, 2 views)
File Type: jpg Durspark Ignition Control Module Back.jpg (17.9 KB, 3 views)
