Old 09-28-2012, 03:49 AM   #1
BILL WZOREK
BILL WZOREK's Avatar
Default More brake bleeding Question>>>
From time to time when bleeding brakes there is a stubborn bleeder that does not want to come out.
Let's hear some of you tried & true methods for getting them out with out braking the bleeder off.
I will post my way after you. [ inother words you show me yours & I will show you mine ] your's may be better.
BILL WZOREK is offline   Reply With Quote
Old 09-28-2012, 06:05 AM   #2
chuck stevens
chuck stevens's Avatar
Default Re: More brake bleeding Question>>>
Try a 3/8" breaker bar with the right size socket. With the breaker bar you can move it in both directions- back and forth. Of coarse lots of penetrating oil. If it brakes off, you needed a new wheel cylinder any way. Good luck Bill, see down in Hershey.
chuck stevens is offline   Reply With Quote
Old 09-28-2012, 06:28 AM   #3
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I've taken a small torch and heated the bleeder screw, the rubbers are a long way from the bleeder and I've never hurt them. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 09-28-2012, 06:40 AM   #4
Dec211975
I use a squirt bottle filled with water, heat the bleeder with a torch to a dull red this will heat up the wheel cylinder then direct the spray on the bleeder; the cold water will cause the bleeder to shrink, immediately brake them free with a six point wrench or socket, and they will turn out easily. The heat will also expand the fluid in the wheel cylinder and sometimes blow a brake line if they are marginal.
Dec211975 is offline   Reply With Quote
Old 09-28-2012, 07:14 AM   #5
Kojack
Bill
If you get the bleeder out put anti-sieze on it when you put it back in so it will not siesze up again.
Kojack
Kojack is offline   Reply With Quote
Old 09-28-2012, 03:36 PM   #6
BILL WZOREK
OK Guys
I am not having a problem but I am sure that there are others that are & I was interested in knowing if my heat with a torch all though I go a little more then dull red
and use a water soaked rag to cool down Quickly.was used by others.
That snti-sieze is a very good idea.
