Old 09-13-2012, 06:33 AM   #1
jim6346
Default Changing Glass
Hi Everyone,
I have new glass for a 31 Tudor rear window. Is there an easy way to remove the old glass from the track? The old glass is already broken so I am not too worried about damage to it. Do I heat the track?
Thanks,
Jim
jim6346 is offline   Reply With Quote
Old 09-13-2012, 06:34 AM   #2
jim6346
Default Re: Changing Glass
Sorry, I meant Rear Side Glass that rolls up and down.
Thanks,
Jim
Old 09-13-2012, 08:45 AM   #3
Doug in NJ
Doug in NJ's Avatar
Do you mean removing the glass from the metal piece across the bottom, that moves the glass up and down? Try working a thin putty knife down either side to free up the glass.
Another handy tip: use mineral spirits as a lube when installing the new glass with the rubber or cork setting material.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 09-13-2012, 09:40 AM   #4
jim6346
I found that if I warmed up the metal the glass pulled right out, along with the rubber piece. I have new rubber material that came with the glass, but I think it is too thin?
The glass with the gasket slides in and out too easy. Am I supposed to use any type of adhesive?
Thanks,
Jim
Old 09-13-2012, 11:54 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Thanks,
Jim
Try to find the correct thickness. Years ago I installed glass into a windhsield frame for a 1930 AA. I bought the setting material from Bratton's and also from Snyder's. The first was too thick and the second was just right. I don't recall which one had the right thickness.
Old 09-13-2012, 08:59 PM   #6
Aerocraft
Aerocraft's Avatar
You also need to be mindful that the replacement safety glass may be thinner than the original glass. Gar Williams
Aerocraft is offline   Reply With Quote
