Old 09-06-2012, 07:30 AM   #1
HOTROD_WILLIE
HOTROD_WILLIE's Avatar
Default Make Your Own flathead Engine Stand
Here are the pics.
HOTROD_WILLIE is offline   Reply With Quote
Old 09-06-2012, 10:44 AM   #2
Shadetree
Shadetree's Avatar
Default Re: Make Your Own flathead Engine Stand
Now that is brilliant! I have Stumpy's but the engine is unbalanced fore and aft on the stand.
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 09-06-2012, 12:21 PM   #3
Russ/40
Russ/40's Avatar
Wow, there is a lot of work and engineering there. Can the crank be removed or installed with the setup?
Russ/40 is offline   Reply With Quote
Old 09-06-2012, 02:37 PM   #4
HOTROD_WILLIE
The engine stand is made from 2 habor freight stand bought from craigslist. The stand is design from original stand back in the day. Big circle in front lets you put the cam in or out.
Old 09-06-2012, 09:12 PM   #5
Russ/40
Russ/40's Avatar
Again, can you install the crankshaft assembly with the block on your stand?
Old 09-06-2012, 09:31 PM   #6
Tim Ayers
I don't see why you can't use you flip it over 180 degrees. May have to slip in the snout first, but sure looks like it.
Tim Ayers is online now   Reply With Quote
Old 09-06-2012, 10:07 PM   #7
jkeesey
jkeesey's Avatar
Wasn't this on the HAMB?
jkeesey is offline   Reply With Quote
Old 09-06-2012, 10:21 PM   #8
Russ/40
Russ/40's Avatar
Yea, I guess you could. Couldn't put the flywheel on it though.
Old 09-07-2012, 06:54 AM   #9
HOTROD_WILLIE
Yes just like a regular stand. This design is based off the design of one made back in the day. GC
Old 09-07-2012, 08:41 AM   #10
Ray in La Mesa
Kool engine stand but that Columbia two speed next to it is even cooler!
Ray in La Mesa is offline   Reply With Quote
Old 09-07-2012, 10:05 AM   #11
1952henry
1952henry's Avatar
One I built. Was being used as a dolly in the picture. Plates bolt to exhaust ports and will spin 360*
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 09-07-2012, 11:06 AM   #12
Russ/40
Russ/40's Avatar
Got a photo of the original design?
52Henry, yours is the first I have seen that uses both sides for the exhaust mount.
Old 09-07-2012, 11:27 AM   #13
HOTROD_WILLIE
GC. The one on the top is my. I used the end of motor. Maybe one day you find one.
Old 09-07-2012, 12:45 PM   #14
1952henry
1952henry's Avatar
I saw one similiar to mine in an old photograph in a V8 Times magazine.
Old 10-05-2013, 08:13 PM   #15
barnfind
The lower priced HF 4 wheel stand works well as an engine storage dolly with a little rework.
barnfind is offline   Reply With Quote
