Old 07-16-2012, 11:34 PM   #1
mike kilger
Default washington blue paint codes
anyone know what the paint code would be? in single stage thanks
mike kilger is offline   Reply With Quote
Old 07-17-2012, 12:41 AM   #2
ken ct
Default Re: washington blue paint codes
Ive seen 15 diff shades of WB,they cant all be right,take your pick. ken ct. I have one for 25 yrs.[not even saying mine is correct] lol
ken ct is offline   Reply With Quote
Old 07-17-2012, 06:49 AM   #3
Capn John
Capn John's Avatar
Try these sites and follow the directions
http://paintref.com/cgi-bin/colorcod...IM1550&rows=50
http://www.autocolorlibrary.com/
http://pc.dupont.com/hcl/?locale=en_US
http://pc.dupont.com/dpc/en/US/html/...r_Library.html
http://www.tcpglobal.com/autocolorlibrary/aclinfo.html
Capn John is offline   Reply With Quote
Old 07-17-2012, 11:11 AM   #4
Tony, NY
I have spent hours, in recent weeks, trying to find WB paint codes. I took the IM1550 code to my local PPG supply and they couldn't do anything with that number. Next, I called the PPG tech line and spoke to a lady in the paint archives. She gave me Nocturne Blue 10989 as the present code for WB. A little investigating finds that as 1953-54 Studebacker color. It looks too dark.
Now Macs sells WB in Lacquer. Really $$$.
Some more numbers I found are PPG 1246.
Dupont G8381. This number leads me to 1987 Isuzu Cavalier Blue. That color looks promising.
You could order it online from TCP Global and take a chance your getting what you want. Maybe order a quart for around $100.
Also, NAPA has a listing for Model A WB. I believe it's not the same as later years (35-38?).
Tony, NY is offline   Reply With Quote
Old 07-17-2012, 11:20 AM   #5
Ed Pitts
Ed Pitts's Avatar
This is the site that my paint guy in Tyler, Texas used to mix my 36 color.
http://paintref.com/paintref/index.shtml
Ed Pitts is offline   Reply With Quote
Old 07-17-2012, 11:26 AM   #6
Tony, NY
Do you have a code off of the can label? Or can you get it?
Old 07-17-2012, 11:40 AM   #7
mike kilger
ok cool thanks guys
Old 07-17-2012, 12:45 PM   #8
ken ct
Originally Posted by Jeff/Illinois View Post
Same here. Washington Blue is about the most un-agreed on paint color on an old Ford right next to Copra Drab and Chicle Drab
Only difference is OUR WB HAS to be the right shade,,,, because I like it!!
Its as i remember as a kid a neighbor had 1 and its pretty close to what i remember. Im ok with it. ken ct.
Old 07-17-2012, 01:32 PM   #9
3738
3738's Avatar
I know the Washington Blue paint on my 37 is correct, because it still has it's original paint job from the factory....
3738 is offline   Reply With Quote
Old 07-17-2012, 01:40 PM   #10
37don
I'm not a paint guy but we have been trying to figure out the color of my 37 and came across a friend with original Ditzler paint chips and color codes.
#1747
Dal: 17=30-25=90-46=164-49=1060 ( for enamel)
DQE: 109=22-120=152-102=338-DX200=358-111=1048 ( for lacquer)
I copied this from the book so double check before you mix. Looking at the book there are a multitude of different Washington blue colors depending the year and paint company. There are also a lot of other blues of different names that are pretty close to Washington blue. These codes are for 1937 Ford.
Good luck, Don
37don is offline   Reply With Quote
Old 07-17-2012, 05:22 PM   #11
Steve/IL
Steve/IL's Avatar
Mike,
The 1932 Ford paint code for Washington Blue is IM-1246. Go to your PPG dealer and give them this color & code and ask for it in DCC which is a single stage enamel. They should have an on-line cross reference for the DCC formula. If they say that they don't have a cross reference, ask them to call the PPG Color Library. If they won't do this for you, they obvious do not want your business bad enough to look further. If that is the case, find another PPG dealer or ask your painter or a trusted body shop that uses PPG product to do it for you.
P.S. Whether PPG's DDC Washington Blue mix is correct is another question.
Good Luck
I've got the old car disease. Thankfully there's no cure!
Steve/IL is offline   Reply With Quote
Old 07-25-2012, 10:19 PM   #12
Fordy
#1747
Good luck, Don
This formula is correct according to the PPG Color Code Brochure I have.
It says: Washington Blue No. 1747 1937,1938
Fordy is offline   Reply With Quote
Old 07-26-2012, 07:01 AM   #13
G.M.
These old formulas do not work with modern paints. Every type of paint needs a specific formula. DuPont has a Lab in Lyonville,Pa. that converts the formulas. My grandaughter used to be the one that did the conversions but got transfered to another department. G.M.
www.fordcollector.com
